Old 06-03-2016, 04:29 PM   #1
Decisis
Mechanically Unsavvy
Decisis's Avatar
Drives: 2014 BRZ Limited SWP
overpipe rubbing>
Wondering if anyone else has this problem or if my scrub mechanical skills are to blame.
I've had a Milltek full headerback sports system exhaust installed for 2 years now. The overpipe was insanely hard, almost impossible to squeeze in. I remember installation being difficult. It is 2.5 so quite thicker than stock overpipe. Every time I go downhill (and only downhill) on rougher roads, I hear a rattling sound near where the overpipe is and I suspect it's rubbing because it's touching the axle or something...
Anyone else have this issue or know what it could possibly be?
Decisis is offline   Reply With Quote
Old 06-03-2016, 04:49 PM   #2
Brayden_23
Drives: Asphalt 2015 FRS
Yes, multiple people have experienced this. Your OP is most likely contacting the subframe. Some people have solved this using aftermarket engine mounts, some have solved it with a hammer
Brayden_23 is offline   Reply With Quote
Old 06-04-2016, 03:54 PM   #3
humfrz
and/or a small crowbar and "wire it over" ..........
humfrz
Old 06-04-2016, 04:10 PM   #4
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The temptation to send this thread off topic is overwhelming.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Endlinks rubbing frs_94 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-16-2016 04:43 PM
Will this set up be a rubbing issue Astroboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-02-2014 08:15 PM
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
