Old 04-15-2016, 09:12 PM   #1
frs_94
Drives: scion frs
Endlinks rubbing
I bought some front whiteline swaybar endlinks and i tried installing them at the shortest setting but when i turn the wheels they rub against my airlift struts.
What can i do to fix this?
Do i lengthen the endlinks?
Sent from my LG-H812 using Tapatalk
frs_94 is offline   Reply With Quote
Old 04-16-2016, 10:55 AM   #2
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
From what I've read on here, it seems the standard Whiteline adjustable endlinks are too long even at the shortest setting. Apparently a lot of people got clunking from them which was fixed by using shorter endlinks. Whiteline makes a shorter adjustable endlink under part number KLC180-195. Feal Suspension also sells their shorter endlinks separately, but they're not adjustable.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
e1_griego (04-16-2016)
Old 04-16-2016, 04:43 PM   #3
frs_94
Drives: scion frs
i was looking at the raceland endlinks and they look very similar to the ones from airlift.
Can anyone confirm if they are the same?
http://raceland.com/scion-frs-end-links.html
Rubbing fender. dito Southern California 34 05-15-2015 01:12 AM
Will this set up be a rubbing issue Astroboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-02-2014 08:15 PM
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
Rubbing issues boricua FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-23-2013 07:28 PM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
