Old 06-03-2016, 11:35 AM   #1
tylerdone86
tylerdone86's Avatar
Drives: Raven Scion FR-S
Idle dipping when the clutch is depressed
I bought my FR-S about 3 months ago, and I've just noticed that when i depress the clutch to come to a stop, it sometimes idle dips to 400rpm and then rises back to idle speed. I have heard about this problem before but i'm not sure if it's normal or if I should carry it to the dealer since I still have warranty on the vehicle still.
P.S. : First post on the FT86 form, I'm in love with my FRS so far.
tylerdone86 is offline   Reply With Quote
Old 06-03-2016, 11:42 AM   #2
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
If your A/C or defrost is on, it's normal. The little 2.0L has to struggle a bit as the compressor cycles.
sly is offline   Reply With Quote
The Following 2 Users Say Thank You to sly For This Useful Post:
gramicci101 (06-03-2016), Tcoat (06-03-2016)
Old 06-03-2016, 12:02 PM   #3
tylerdone86
Thanks, I'll be sure to try turing off the A/C and see if the problem still persists
Sent from my ASUS_Z00AD using Tapatalk
Old 06-03-2016, 12:36 PM   #4
extrashaky
Drives: 2014 BRZ Limited
That's normal. Not a problem. Just another weird quirk of this car.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (06-03-2016)
Old 06-03-2016, 02:51 PM   #5
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Does it make a rattling noise under the hood (video on post #3) a moment before the RPM drops? If so, then it happens on mine too, but not as low as 400. Mine's probably 500. But low enough to feel the shudder.
Sigh-on-Rice is offline   Reply With Quote
Old 06-03-2016, 03:21 PM   #6
Mine will do this (down to about) for a second if I just came off a long highway run or traveled a few blocks at high revs and then come to a complete stop without a slow down period. Like Extra said I just consider it another foible of this car and am not concerned.
Old 06-03-2016, 07:11 PM   #7
8R6
8R6's Avatar
Drives: FRS
mine does that too, and if im behind like a pickup truck or suv sometimes i can even see my drl's almost turn off and turn back on lol :/
8R6 is offline   Reply With Quote
Old 06-03-2016, 07:21 PM   #8
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
This isn't even a quirk of this particular car, it's typical across the board
Toyarzee is offline   Reply With Quote
Old 06-03-2016, 09:13 PM   #9
stevesnj
stevesnj's Avatar
With the ac on and both fans running and then the AC cycles or you turn the fan up, DRL's on, or Headlights on, then the music is up with the amp pulling some amps.Thats a big amp draw at low rpm at a light. Dunno what AMP our Alternators are but it seems to be sufficient, maybe 10-20 amps more would be nice.
My 2016 Build thread
Clicking noise from clutch when depressed/released? BaeK Issues | Warranty | Recalls / TSB 30 02-05-2025 05:20 PM
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 08:03 PM
Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. Rybot Issues | Warranty | Recalls / TSB 35 03-06-2016 08:23 PM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 10:15 AM
starting to feel really depressed 20valvewynn83 Off-Topic Lounge [WARNING: NO POLITICS] 15 09-28-2012 03:13 AM
