Old 05-19-2016, 07:42 PM   #1
lupindub
Drives: Scion FR-S
Do these wheel's require 45 degree lug nuts?
So I just put on some Enkei RP03's using your standard 60 degree extended lug nuts and it doesn't seem to hold the torque for more then a day. I used a properly calibrated torque bar. I have to re-tighten them about 1/2 a turn every day. The threads are not stripped since as soon as I do the 1/2 turn, they are impossible to turn any farther. Only 1 or 2 lug nuts seem to coming loose per wheel. So do these Enkei require 45 degree lug nuts or 60 is fine?
http://enkei.com/shop/racing/rp03/
lupindub is offline   Reply With Quote
Old 05-19-2016, 08:06 PM   #2
8R6
8R6's Avatar
Drives: FRS
does this happen to all 20 lug nuts? i cant imagine enkei making this one wheel requiring 45deg tapered seats......
8R6 is offline   Reply With Quote
Old 05-19-2016, 08:19 PM   #3
lupindub
Drives: Scion FR-S
Like I mentioned in my original post in only happens to 1 or 2 nut per wheel.
This is my 3rd set of wheel and nothing like this has happened before.
Enkei advertises these wheel's as "Racing". I just checked out the Wikipedia page on lug nuts and here is what it said - "The lug's taper is normally 60 degrees (although 45 is common for wheels designed for racing applications)."
So could Enkei have designed there "Racing" series wheel's to accommodate only 45 degree nuts?
Old 05-19-2016, 08:48 PM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Are these brand new wheels? I had to re-tighten my NT03+M's a couple of times when I first got them, but they've been fine ever since.
jawn is offline   Reply With Quote
Old 05-19-2016, 08:58 PM   #5
lupindub
Drives: Scion FR-S
Nope not brand new. Bought them used but they are new for me (just put them on yesterday.)
I also noticed the hole where the lug nut goes on the wheel is WAY deeper then any wheel I have ever used. It almost looks like the wheel is sucking up the lug nut when you fully torque them down. These are extended lug nuts too.
Old 05-19-2016, 09:07 PM   #6
8R6
8R6's Avatar
Drives: FRS
oops. missed that part lol
just read your last post, do these wheels take the "tuner" style lugs? the really small skinny ones?
Old 05-19-2016, 09:21 PM   #7
lupindub
Drives: Scion FR-S
I'm using something similar to these:
Old 05-20-2016, 12:49 AM   #8
8R6
8R6's Avatar
Drives: FRS
those look like the regular 19mm ones. But then I just realized if the wheels really did use the smaller diameter ones, these lugs won't even thread on to begin with anyway so nevermind lol
Old 05-20-2016, 02:20 AM   #9
sqd
sqd's Avatar
Drives: '13 SWP GT86
If they would require anything other than the standard type of aftermarket lug nut, it would be mentioned on either Enkeis own product page, or somewhere on the many retailers' websites, otherwise 95% of the people buying them would have the same issue. I'm sure you're supposed to use the 60-degree type nuts you are using.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 05-20-2016, 08:43 AM   #10
stevesnj
stevesnj's Avatar
Could be that the nuts are bottoming out. Try open end lug nuts
My 2016 Build thread
Old 05-20-2016, 11:44 AM   #11
8R6
8R6's Avatar
Drives: FRS
good point
Old 05-20-2016, 03:19 PM   #12
lupindub
Drives: Scion FR-S
After re-torquing the wheel's for the fourth time, it seems to have stayed put for now. Guess the new nuts were just settling in with the wheel's? Not sure but I am happy the problem has resolved it self.
Muteki Wheel Nuts - chipping paint Hags86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-26-2015 09:17 AM
Wheel Nuts Free to Good Home. Taken. Gone. No More. Captain Snooze Australia Classifieds 1 08-27-2013 08:15 PM
Some interesting background on oil that doesn't require a chemistry degree Chimpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-11-2013 10:24 PM
Alu Wheel nuts.. Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-26-2013 07:28 PM
Calling all wheel nuts. Staticfrost AUSTRALIA 90 06-13-2012 09:33 AM
