Old 05-15-2016, 01:45 PM   #1
Jonsey
Jonsey's Avatar
Broken strut bar mount
Just thought I would share this as I don't recall having seen others with this issue before.
Started hearing a clunking noise driving home Thursday night that sounded like it was coming from the front suspension. Car has been tracked many times so I figured something was wearing out or finally giving in. After pushing and pulling on many things, I figured out the passenger side strut bar mount had broken where three of the spot welds were and had sheared the fourth spot weld. The strut bar mounts are really only held on by the factory with four spot welds...
I have been running the GS strut bar for a year or two now. I am going to weld the mount back on and then find a strut bar that mounts using the three screws for the actual strut mounts.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jonsey For This Useful Post:
Guff (05-25-2016), whataboutbob (05-25-2016)
Old 05-15-2016, 09:55 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Had the car been previously crashed? Do you hit a lot of curbing?
Old 05-16-2016, 02:57 AM   #3
Jonsey
Jonsey's Avatar
Car has never been crashed and don't hit much curbing. It has been several months since I have been to the track and I can't remember hitting any bump that I thought was particularly jarring.
Old 05-16-2016, 08:33 AM   #4
mrk1
Drives: Sterling BRZ Ltd
I'm surprised this doesn't happen more, its just spot welds.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-21-2016, 02:11 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
whoa narly!
Old 05-25-2016, 10:43 AM   #6
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Whoa, that's something we haven't seen before! Including all the other designs that have adopted the same mounting method. We've had ours on our car, run hard, for 3 years now and no signs of anything like that.
I'm guessing it has something to do with the track time and curbing that may have fatigued those spot welds, but it could also be a vehicle defect. We'll keep an eye out for any other failures, but we do not expect them as these pick up points were designed to handle lateral loads, as well as braking loads!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
JazzleSAURUS (05-25-2016), Jonsey (05-27-2016)
Old 05-25-2016, 11:18 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Geez. This makes me want to get out ye olde welder...
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 05-25-2016, 07:27 PM   #8
stevesnj
stevesnj's Avatar
Hmmm might be why STi developed the flex joint brace.
Here's an older thread about the STi brace and how good it is. Also reading around it seems solid braces are meant mostly for track use where this flex design allows for potholes, rougher roads and vertical forces typically not experienced on the track. It may be vertical movement that could of caused this break not horizontal. I'm still reading up on all this.
http://www.ft86club.com/forums/showthread.php?t=22441
My 2016 Build thread
Old 05-25-2016, 07:39 PM   #9
sw20kosh
Drives: 2013 Black FR-S
Grim bar is too good.
Old 06-08-2016, 08:06 PM   #10
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
You can see that the TRD tower bar is carbon fiber, which also allows for vertical movement (we are talking about millimeters here) with flex but prohibits horizontal deflection.
Old STI tower bars were either made out of carbon fiber or titanium with the same idea in mind and they have been around since the 90's.
You get what you paid for.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
stevesnj (06-09-2016)
Old 06-09-2016, 08:48 PM   #11
stevesnj
stevesnj's Avatar
Yeh a solid bar preventing vertical movement could be damaging in a street car. Interesting
Old 06-09-2016, 09:08 PM   #12
grodenglaive
Drives: asphalt FR-S
Oh that's why "flexible" strut bar!
For the life of me I couldn't figure out why anyone would make a flexible strut bar - it seemed to defeat the purpose. Good to know.
grodenglaive is offline   Reply With Quote
Old 06-09-2016, 10:25 PM   #13
krayzie
Drive From Home
krayzie's Avatar
Well the Nurburgring isn't a perfectly flat track either.
Old 06-10-2016, 12:44 PM   #14
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
At least it should be a pretty easy fix - obviously have a beat laid (welded) around as much of it as there can be and paint it to prevent rust. At least it's something track folk know to look out for now...
axelthrasher is offline   Reply With Quote
Bad Strut Mount Bearing Estey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-22-2016 03:54 AM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
HELP PLEASE! - A/C pulley mount broken, can I still safely drive the car? NLSP Engine, Exhaust, Transmission 4 11-01-2014 05:46 AM
Broken Stut mount Stud. Anyone Did This Before? Figo Issues | Warranty | Recalls / TSB 3 07-19-2013 10:29 AM
