Old 05-11-2016, 03:54 PM   #1
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
My Racer X / Setrab oil cooler install
My parts:
Setrab 9-series STD 15.94"x4.53" pn: 50-915-7612
Setrab brackets pn: 23-9002
Setrab adapters AN10 - M22 pn: 22-M22AN10-SE
Racer X Fabrication thermostatic sandwich plate, no finish pn: 02004X-AN-RAW
fitting at plate: Summit Racing AN10 o-ring to AN10 flare adapter pn: SUM-220164N
hose: 2 x 3' AN10 black nylon hose, Summit Racing pn: SUM-240003B
hose ends: 3 x Russell Endura AN10 90degree, nickel finish, pn: 610181
1 x Russell Endura AN10 45 degree pn: 610111
some parts pictured:
snuff58 is offline   Reply With Quote
The Following User Says Thank You to snuff58 For This Useful Post:
ZionsWrath (05-11-2016)
Old 05-11-2016, 04:02 PM   #2
snuff58
snuff58's Avatar
More to come . . . . . out of time, just now!!!
Please, NO comments until I have finished!!!!
Old 05-11-2016, 05:16 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
First
The Following 8 Users Say Thank You to ZionsWrath For This Useful Post:
Cole (05-12-2016), Freeman (05-11-2016), gramicci101 (05-12-2016), JohnJuan (05-12-2016), kch (07-12-2018), mixtape (05-12-2016), SkAsphalt (05-11-2016), yberther (05-12-2016)
Old 05-12-2016, 09:50 AM   #4
snuff58
snuff58's Avatar
Well, I am having a hard time getting my images I stored in imgur to show.
More patience, please. (maybe my efforts to share are resulting in too much trouble to continue)(we'll see....)
Old 05-12-2016, 11:04 AM   #5
snuff58
snuff58's Avatar
Here is the 90 degree hose end:
Old 05-12-2016, 11:06 AM   #6
snuff58
snuff58's Avatar
I chose the Setrab 9 series cooler. I did not want to mount it on the plastic shelf behind the bumper. I wanted securely use the manufacturer's brackets, and mounted it on the back of the collision bar. I had a friend make these brackets from aluminum:
Old 05-12-2016, 11:07 AM   #7
snuff58
snuff58's Avatar
Bumper removed:
Old 05-12-2016, 11:08 AM   #8
snuff58
snuff58's Avatar
Collision bar removed:
Old 05-12-2016, 11:09 AM   #9
snuff58
snuff58's Avatar
Showing the spacing for the mounting holes using the Setrab bracket as a guide:
Old 05-12-2016, 11:13 AM   #10
snuff58
snuff58's Avatar
Here is a shot of the collision bar with all for holes drilled to accept rivet nuts:
The Following 2 Users Say Thank You to snuff58 For This Useful Post:
Hyper4mance2k (07-07-2024)
Old 05-12-2016, 11:15 AM   #11
snuff58
snuff58's Avatar
I sprayed some paint in each hole edge to help deter corrosion. Here is one rivet nut installed, followed by all 4.
Old 05-12-2016, 11:16 AM   #12
snuff58
snuff58's Avatar
Old 05-12-2016, 11:17 AM   #13
snuff58
snuff58's Avatar
Here is the Setrab w/ brackets mounted to the collision bar with my custom-made brackets.
Old 05-12-2016, 11:18 AM   #14
snuff58
snuff58's Avatar
and bar mounted:
DAEMANO (05-12-2016)
FS: Setrab 19 Row Oil Cooler byun Engine, Exhaust, Bolt-Ons 24 10-16-2015 02:07 PM
*BRZ Part Out* Setrab oil cooler kit xDanger_208x Engine, Exhaust, Bolt-Ons 12 04-07-2015 08:50 AM
FS: Setrab oil cooler. Vortech V3 oil. MyRx Engine, Exhaust, Bolt-Ons 7 03-20-2015 01:23 PM
Setrab/Perrin oil cooler jack43 Engine, Exhaust, Bolt-Ons 2 11-24-2014 01:59 AM
Setrab 10 Row Oil Cooler *SOLD* Captain Snooze Australia Classifieds 0 07-08-2013 06:18 AM
