Drives: Subaru BRZ
17x9 +45 rubbing fender liner with coilovers
Is it normal for this size wheels to rub with coils(not installed anymore)?
Is it an alignment issue? You can see on the inside of the wheel it rub around the whole wheel and on the wheel weight. The thing is I couldn't find anywhere else it was rubbing except on the fender liner. Didn't see any contact on the coils or suspension parts. Maybe it's an issue when on full lock. The other side has the same rubbing not quite as bad as this side though. See pics http://iforce.co.nz/i/2kyk4do0.j4d.jpg http://iforce.co.nz/i/lau5xmmh.chd.jpg http://iforce.co.nz/i/lm4muass.peg.jpg http://iforce.co.nz/i/tjjgdkei.hye.jpg http://iforce.co.nz/i/3oiaf0j4.dqo.jpg |
#2 | |
Drives: 10 Series #974 6m/t
Ridge Racerrrrrrrrr
You have an alignment issue. You should not need spacers at all for this
Also, how low are you? If you go too low, you will rub.
Drives: '13 SWP ZC6 R
I'm not sure what's worse in this section - the questions missing (most of) the relevant information, or the garbage feedback (typically) from low post count members...
I digress, the inside of your wheel is not rubbing your fender liner. Your tire is rubbing your fender liner. You didn't tell us your tire size, alignment specs, coils used (or pics), or ride height. Thank you, come again.
#6 | |
Drives: Subaru BRZ
i didn't see any other marks where the wheel tyre contact but how did the inside of the wheels get scraped like that ? my coils were k sport coilovers not sure on alignment specs i wasn't crazy low heres a pic of how it sat
Did you check the control arm? The fender liner won't do that to the wheel. It is rubbing something metal. Most likely control arm.
Drives: 2015 BRZ CWP
I run the same offset but 18x9.5 with 255/35 tires and only rub the fender liner at full lock right.
I'm running Cusco sway bars right now but when I had eibach's the inside tire of the passenger side would come in contact with it on full lock right turns as well. My alignment specs are -2.4 and 0 toe in front and lowered about .75 inches on kW v3's Might what to check end links and sway bar to see if there are any marks and maybe the spring perches. Sent from my iPhone using Tapatalk |
Drives: 2015 Scion FRS
I'm on the same offset but 18x8.5 in the front, 235/35, lowered about 1.5 inches, 2.2 degrees camber and just a tiny bit of toe out. No rubbing for me
Sent from my SAMSUNG-SM-G928A using Tapatalk |
#10 |
Drives: Subaru BRZ
It's weird man Im looking everywhere but can't see any metal parts with any damage.
#11 |
Drives: 2013 Scion FRS firestorm
I have 17x9 +45, 245/40/tires, coils lowered 1"-1.5" -2.5 ish camber 0 toe. No rubbing.
#12 | ||
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Did you ever get the car professionally aligned? |
#13 |
Country Boy 4 Life
Weird, I don't usually see both kinds of wheel weights used on the same wheel. |
#14 |
Drives: 2017 BRZ
So I'm going to disagree a little and suggest it isn't metal on metal... Unless it's pretty thin and flexible. The wear pattern at the weight is different, so that has to be successfully pushing whatever causes the wear away while not being torn off.
That said, the wear is really oddly placed. Steering turnbuckle seems most likely. There may be enough bushing flex to behave as noted with the weight. |
| RUBBING with 17x9 +35 | Devil 86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 04-25-2016 01:12 PM |
| Fender Liner Removal? | smg1138 | Tracking / Autocross / HPDE / Drifting | 2 | 11-04-2015 12:11 PM |
| Rubbing fender. | dito | Southern California | 34 | 05-15-2015 01:12 AM |
| Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? | Eazy-V | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 11-02-2014 09:42 PM |
| WTB: FRONT FENDER LINER | mr. slim | Want-To-Buy Requests | 0 | 01-06-2014 05:05 PM |
