Old 05-11-2016, 05:18 AM   #1
nomis
Drives: Subaru BRZ
17x9 +45 rubbing fender liner with coilovers
Is it normal for this size wheels to rub with coils(not installed anymore)?
Is it an alignment issue?
You can see on the inside of the wheel it rub around the whole wheel and on the wheel weight.
The thing is I couldn't find anywhere else it was rubbing except on the fender liner. Didn't see any contact on the coils or suspension parts.
Maybe it's an issue when on full lock. The other side has the same rubbing not quite as bad as this side though.
See pics
http://iforce.co.nz/i/2kyk4do0.j4d.jpg
http://iforce.co.nz/i/lau5xmmh.chd.jpg
http://iforce.co.nz/i/lm4muass.peg.jpg
http://iforce.co.nz/i/tjjgdkei.hye.jpg
http://iforce.co.nz/i/3oiaf0j4.dqo.jpg
nomis is offline   Reply With Quote
Old 05-11-2016, 02:30 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
See pics
looks like a 3mm to 5mm spacer is required.
Old 05-11-2016, 07:00 PM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You have an alignment issue. You should not need spacers at all for this
Old 05-11-2016, 07:55 PM   #4
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Also, how low are you? If you go too low, you will rub.
JDMChris is offline   Reply With Quote
Old 05-11-2016, 08:08 PM   #5
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
I'm not sure what's worse in this section - the questions missing (most of) the relevant information, or the garbage feedback (typically) from low post count members...
I digress, the inside of your wheel is not rubbing your fender liner. Your tire is rubbing your fender liner. You didn't tell us your tire size, alignment specs, coils used (or pics), or ride height. Thank you, come again.
sdemo is offline   Reply With Quote
Old 05-11-2016, 08:15 PM   #6
nomis
Drives: Subaru BRZ
tyres were 235/45/17
i didn't see any other marks where the wheel tyre contact but how did the inside of the wheels get scraped like that ?
my coils were k sport coilovers
not sure on alignment specs
i wasn't crazy low heres a pic of how it sat
Old 05-11-2016, 08:52 PM   #7
JDMChris
Drives: 2016
Did you check the control arm? The fender liner won't do that to the wheel. It is rubbing something metal. Most likely control arm.
Old 05-11-2016, 09:46 PM   #8
byun
byun's Avatar
Drives: 2015 BRZ CWP
I run the same offset but 18x9.5 with 255/35 tires and only rub the fender liner at full lock right.
I'm running Cusco sway bars right now but when I had eibach's the inside tire of the passenger side would come in contact with it on full lock right turns as well.
My alignment specs are -2.4 and 0 toe in front and lowered about .75 inches on kW v3's
Might what to check end links and sway bar to see if there are any marks and maybe the spring perches.
byun is offline   Reply With Quote
Old 05-12-2016, 09:38 AM   #9
mpross
mpross's Avatar
Drives: 2015 Scion FRS
I'm on the same offset but 18x8.5 in the front, 235/35, lowered about 1.5 inches, 2.2 degrees camber and just a tiny bit of toe out. No rubbing for me
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 05-12-2016, 09:42 AM   #10
nomis
Drives: Subaru BRZ
It's weird man Im looking everywhere but can't see any metal parts with any damage.
Old 05-12-2016, 05:27 PM   #11
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I have 17x9 +45, 245/40/tires, coils lowered 1"-1.5" -2.5 ish camber 0 toe. No rubbing.
Mad_Mike is offline   Reply With Quote
Old 05-12-2016, 05:44 PM   #12
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
What they said ^....
Did you ever get the car professionally aligned?
Old 05-12-2016, 05:46 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Weird, I don't usually see both kinds of wheel weights used on the same wheel.
Old 05-12-2016, 11:54 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
So I'm going to disagree a little and suggest it isn't metal on metal... Unless it's pretty thin and flexible. The wear pattern at the weight is different, so that has to be successfully pushing whatever causes the wear away while not being torn off.
That said, the wear is really oddly placed. Steering turnbuckle seems most likely. There may be enough bushing flex to behave as noted with the weight.
RUBBING with 17x9 +35 Devil 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-25-2016 01:12 PM
Fender Liner Removal? smg1138 Tracking / Autocross / HPDE / Drifting 2 11-04-2015 12:11 PM
Rubbing fender. dito Southern California 34 05-15-2015 01:12 AM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 09:42 PM
WTB: FRONT FENDER LINER mr. slim Want-To-Buy Requests 0 01-06-2014 05:05 PM
