Old 05-10-2016, 10:17 PM   #1
yutinggao
yutinggao's Avatar
Drives: Gr86
Need help with hydro EBrake!
I just bought a hydro Ebrake and two extra oem rear caliper, Does anyone here know where can I get the bracket that can mount two calipers on? Anything will help! Thanks!
yutinggao is offline   Reply With Quote
Old 05-10-2016, 11:52 PM   #2
Knshro13
Drives: 10 series FRS
I can help you without knowing any of the above post.
Wisefab makes a full suspension kit for our cars. The rear kit hub assembly has two caliper bracket mounts that utilizes factory mounting positions. So, one for stock rear caliper, and the other for a secondary caliper for hydraulic hand brake.
As for just adding a bracket, we have made one before but it was completely custom. Wisefab is true bolt on.
However..... I don't recommend a wisefab kit for the street unless you're hardcore. In my experience with WiseFab, the hardware comes loose too easily. This is an easy fix for me since I only use it in competition. I simply tighten them after a few runs. So I hope you're hardcore enough.
Knshro13 is offline   Reply With Quote
Old 05-11-2016, 11:49 AM   #3
kch
Senior Misanthrope
kch's Avatar
Spencer Fab makes a dual caliper rear bracket.
http://spencerfabrication.squarespac...unting-bracket
Old 05-11-2016, 12:18 PM   #4
yutinggao
yutinggao's Avatar
Drives: Gr86
really thanks!
Old 05-11-2016, 12:19 PM   #5
yutinggao
yutinggao's Avatar
Drives: Gr86
thank you!
Old 05-11-2016, 12:40 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I started at Drift Day single digits. Is that hardcore enough?
-alex
Old 05-11-2016, 06:49 PM   #7
yutinggao
yutinggao's Avatar
Drives: Gr86
but spencer does not make them any more
Old 05-12-2016, 09:15 AM   #8
mrk1
Drives: Sterling BRZ Ltd
Spencer is just out of stock for now, there is a difference
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-12-2016, 10:54 AM   #9
FRS Justin
Drives: 2013 Asphalt FRS
He makes them, he is just working on a trans swap... I want a set so I'm waiting. The last thing I need is to pull the brake and a China made part puts me in the wall.. After all it's your brakes!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-22-2018, 11:41 AM   #10
Pschultz91
Drives: 2013 Frs
Here is a braket that will support an extra caliper. I plan on buying it soon. http://www.ft86speedfactory.com/dayt...l#.XB5pCC2ZPVo
Pschultz91 is offline   Reply With Quote
Need help with hydro EBrake! yutinggao Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-11-2016 06:46 PM
Hydro Dipping graeme02 AFRICA 1 02-12-2016 07:17 AM
Hydro Ebrake? Hellias Tracking / Autocross / HPDE / Drifting 0 04-06-2015 11:12 AM
Is it possible to get hydro lock through car wash? Muskokan Issues | Warranty | Recalls / TSB 1 10-15-2014 02:37 PM
Anyone tried hydro dipping before? Frs300 Cosmetic Modification (Interior/Exterior/Lighting) 14 07-07-2013 02:29 PM
