Old 04-03-2014, 08:15 AM   #1
frslee
Just drive it
Drives: 13' FR-S
How do 2 different pairs of tire affect handling?
I wasn't sure whether this thread belongs here or in track/hpde section. Since it involves tires.. I'll put it here.
So I bought a set of used wheel/tire and tires are 2 yokohama s drive (30-40%) and 2 Federal SS595 (60-70%). I may bring these to track to wear them out and get new summer tires.
My question is.. since our cars are prone oversteer, should I use Federal in the rear to give more traction? I know s drive is better than ss595 but since federal has more rubber left, I thought that would provide more grip. I'll also have lower tire pressure in the rear. All suspension/chassis/brake parts are stock.
frslee is offline   Reply With Quote
Old 04-03-2014, 11:19 AM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
If you're headed to the track, why not swap them every other session? See what you like best/what works okay?
Old 04-03-2014, 12:20 PM   #3
frslee
Just drive it
Drives: 13' FR-S
@Shutter The thing is that I'm only going to 1 session for this month.
Old 04-03-2014, 12:52 PM   #4
wparsons
wparsons's Avatar
He meant lapping sessions, not full days. Typically lapping days, HDPE, etc are broken down into run groups and you have to stick with your group, so you would have 20 minutes on track, then time off depending on the number of groups.
Plenty of time to rotate tires if you wanted.
flickr
Old 04-03-2014, 02:42 PM   #5
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
I have been running two Hancook Ventus V2's and two OEM tires and have had them rotated twice. It works about like you would expect, the grippier tires in back help with the tail wagging and acceleration. In the front, the grippier tires helped with cornering, braking and eliminated some poor-driver-induced understeer.
If you are like me on the track, I was too slow in and too fast out so the grip would be best in the back. If you are a late breaker, I would put the grip in front.
5hairpins is offline   Reply With Quote
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
Question? Plxdjake89 Scion FR-S / Toyota 86 GT86 General Forum 7 07-28-2012 03:31 PM
TCS/VSC question. Cheddar Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 08:29 PM
AT question Rob_g Scion FR-S / Toyota 86 GT86 General Forum 2 05-25-2012 02:40 AM
