Old 05-01-2016, 12:20 AM   #1
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Rods & Pistons install cost
Anyone had forged rods and Pistons installed? Boosting soon and am considering getting them at some point for more boost action. How much did it cost to get them installed?
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 05-01-2016, 12:42 AM   #2
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
@smudge
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 05-01-2016, 07:30 AM   #3
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
It depends, could range from $1500-2500 It will be cheaper if you have access to a engine hoist and can take out and install the motor yourself. But it varies from build to build, and whats needed/ what you want.
R2RO is offline   Reply With Quote
The Following User Says Thank You to R2RO For This Useful Post:
MisterSheep (05-06-2016)
Old 05-01-2016, 08:31 AM   #4
raven1231
I know a guy who does them for 300 installed. He's the best bro, Street tuned my CX racing turbo kit and it rips.
The Following 4 Users Say Thank You to raven1231 For This Useful Post:
Cole (05-01-2016), jawn (05-01-2016), kch (06-22-2016), MisterSheep (05-06-2016)
Old 05-01-2016, 10:58 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If that were the case, and he did great work, it would be totally worth it to drive to Ohio just to build an engine. haha
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
@Art_Mighty (06-29-2016), MisterSheep (05-06-2016), raven1231 (05-01-2016)
Old 05-01-2016, 04:21 PM   #6
wise345
wise345's Avatar
If just have the shop pull and install the engine
Old 05-01-2016, 04:46 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
In case OP isn't aware of your sarcasm, you are just confusing the op. And, my CX Racing oil cooler works well once you Teflon tape each and every threaded part.
From what I have read, once the engine is removed you are at least $1500 labor plus plus. Pistons and connecting rods apparently can be swapped from the bottomm after removing oil pan. Apparently the Subaru piston and crank can be pulled out with the head intact?? Parts probably $1500. thereabouts. Not sure but if this can be done without removing engine,but if nothing needs to be done with valves or valve springs, there could be a ton of savings on billable labor.
You need to replace rods if doing pistons. The rods incidentally appear to be the weak link under high torque.
The Following User Says Thank You to wbradley For This Useful Post:
Astroboy (05-20-2018)
Old 05-06-2016, 07:28 AM   #8
AJPG
Drives: 22RE, FA20, 4G63
From what I have read, once the engine is removed you are at least $1500 labor plus plus. Pistons and connecting rods apparently can be swapped from the bottomm after removing oil pan. Apparently the Subaru piston and crank can be pulled out with the head intact?? Parts probably $1500. thereabouts. Not sure but if this can be done without removing engine.
For your own good remove the engine, it will look harder but it's not, having oil leaks or poor torque screws ain't nice...
AJPG is offline   Reply With Quote
The Following 2 Users Say Thank You to AJPG For This Useful Post:
Astroboy (05-20-2018), MisterSheep (05-06-2016)
Old 05-06-2016, 11:56 AM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
470whp on the CX kit with a 5558.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZoomTX For This Useful Post:
Old 05-06-2016, 01:24 PM   #10
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
The fa20 engines need the heads removed because there is no wristpin access hole to swap rods. So of you want pistons and rods you're looking at pulling the motor.
I'd do valve springs at the same time. If low enough miles and you don't mix up the valves. Valve reseating is cake.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
brosifSmith (04-28-2019)
Old 06-22-2016, 06:36 AM   #11
pleong
Drives: 2013 Whiteout FR-S
The heads must be removed... there's no way to remove the rods and pistons without removing the heads...
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 06-22-2016, 09:02 PM   #12
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Every shop is different, but we generally do 3k flat rate for R&R of the motor and building the motor. If the car is not here, then it is 2k for long block assembly, 1500 for short block assembly. We're one of the very few shops that will do an actual FA20 long block and not just a short block.
Either way there's no "easy" or cheap way to do it. You have to pull the motor, tear everything apart, and then reassemble the right way. The best thing to do is to do all this before the motor blows. If it is low mileage, we usually do a quick hone for a new ring sealing surface, deck the heads and engine cases, and that is enough for 99% of people up to 600 whp or so. Probably more, but that's as far as we have gone without closing the deck. Given that the cylinder wall thickness is pretty robust for an open deck motor, you may be able to get away higher without closing it...but that's a whole other conversation.
Most builds we see range from 5k in and out with a simple rebuild of a non-damaged motor, up to 11k if the cases are shot and heads are damaged. The price difference is pretty staggering, so the earlier you build it the cheaper it is in the long run. The only caveat is that if you're running under 275 whp, you'd be very unlucky to have the motor go. Even at low to mid 300's it is pretty rare.
Xero-Limit is offline   Reply With Quote
The Following 6 Users Say Thank You to Xero-Limit For This Useful Post:
alphasaur (11-21-2021), Calum (11-21-2021), Dbjunk (11-17-2017), Joveen (10-12-2018), Strife26 (12-05-2017), TofuJoe (06-07-2017)
Old 11-20-2021, 11:20 PM   #13
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Well I guess I'm one of the unlucky ones.
Sent from my Pixel 3 using Tapatalk
dynarun55 is offline   Reply With Quote
Old 11-21-2021, 12:26 PM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
Does that hold true for 91 octane?
machine work for forged rods with stock pistons? Andew727 Engine, Exhaust, Transmission 17 07-27-2017 02:47 AM
Which Forged Rods and Pistons sam69 Forced Induction 19 01-13-2015 08:13 PM
Building my motor I need help on which pistons and rods and which ones to get at a Anthony7515 Engine, Exhaust, Transmission 23 09-21-2014 10:03 PM
12.5/1 Comp Forged Rods and Pistons Darryljr11 Engine, Exhaust, Transmission 1 10-26-2013 07:11 PM
Forged pistons and billet rods paraguin Engine, Exhaust, Transmission 0 09-25-2012 09:55 PM
