Old 12-04-2014, 03:02 AM   #1
sam69
Drives: GT 86
Which Forged Rods and Pistons
Have been searching the net for forged internals and was wondering what peoples opinions are when it come to rods and pistons for FI.
Thinking of going to a 9:1 piston (on ozzy 98 fuel)
Have listed brands below and would like to hear the good the bad and the ugly (if there is any)
Rods ; 1) Brian Crower I Beams
2) Manly Turbo Tuff
3) CP Carrillo
Pistons 1) JE Forged
2) CP Carrillo Forged (leaning towards these as have heard only good things so far).
Looking at APR head studs and was wondering if it's worth putting wet liners like the "Darton Scion FRS Subaru BRZ MID Sleeves".
Any first hand experience would be good but please keep it on topic
sam69 is offline   Reply With Quote
Old 12-04-2014, 03:35 AM   #2
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Pauter not an option for the rods?
I've had CP's in my last 2 built EJ257's, the first one was built loose and used 1L of oil per 1000km, the next bottom end was assembled by a different shop (perfourmance) and it uses no oil.
I had Pauter rods in the first engine and now have Manly's in the current engine. I'd say your power goal/RPM range would be the biggest influence on the rod selection.
Any particular place in mind for the machine work?
If I need to build my FA I'll be going with 10:1 CP's and Pauter rods, probably wouldn't sleeve the block as then I'd be really pushing the power limits and turning the gearset to mush. I'd use JHH for the machine work and assemble myself.
JP is offline   Reply With Quote
Old 12-04-2014, 07:02 PM   #3
sam69
Drives: GT 86
Didn't know about the Pauter rods but will check them out.
Haven't got a place in mind as yet and would be in Perth but will be doing most of the work myself at this stage .
What's the idea of 10:1 compared to 9:1 as would be running about 18 psi and I've been told that with lower comp it is easier to tune and you can put more timing in so more power safely .
Was going to go 10:1
Old 12-05-2014, 07:26 AM   #4
JP
Backyard Fabricator
don't forget you have direct injection available so you can push more boost with higher compression ratio.
18psi from what turbo?
You'll be more likely to hammer your rod bearings than crack a ringland with CP's if you make it detonate.
Old 12-05-2014, 10:39 AM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Generally, low boost on anything over 11:1 CR, mild boost (12-20 psi) on 10-11:1 CR and high boost (26+) on anything lower than 10:1.
Old 12-05-2014, 04:11 PM   #6
350matt
Drives: toyota mr2/ Toyota GT86
how about 9.5:1 ?
350matt is offline   Reply With Quote
Old 12-06-2014, 08:54 AM   #7
sam69
Drives: GT 86
Originally Posted by 350matt View Post
how about 9.5:1 ?
That's what I was thinking but Carrillo doesn't do 9.5:1 only 9 and 10:1
Old 12-06-2014, 04:04 PM   #8
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
You can run a 10:1 DI boosted engine on U.S. regular unleaded (87 AKI, 91 RON).
Don't go too low. I wouldn't go less than 10:1 on a DI engine. That's already a drastic drop in static compression...
Sellout is offline   Reply With Quote
Old 12-06-2014, 04:33 PM   #9
Frs300
Frs300's Avatar
Drives: Pile of junk
how about 9.5:1 ?
you can get custom cps made
Frs300 is offline   Reply With Quote
Old 12-07-2014, 12:49 AM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Id suggest 9.8363051:1 CR. Sounds about perfect.
Old 12-20-2014, 10:45 PM   #11
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Cp carillo seem to be the only rods with a sawtooth split between the cap and rod. Probably to reduce chances of spinning a bearing.
Darryljr11 is offline   Reply With Quote
Old 12-21-2014, 07:04 PM   #12
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
I've got arp head studs, pauter rods, acl bearings, JE 10:1 pistons and built heads.
My tuner recommended this setup, and element tuning is running the same setup on their race frs with great results.
Good luck with the build
BRZGM3 is offline   Reply With Quote
Old 12-22-2014, 07:00 AM   #13
sam69
Drives: GT 86
Thanks for the info and wondering how long have you been running this setup for and have you had any issue at all to date.
Old 12-22-2014, 11:17 AM   #14
BRZGM3
BRZGM3's Avatar
I only put about 35 miles on it, before my friend slid the car into a curb. The repairs should be getting finished up this week.
Its not really an issue, but the internals are definitely way louder than factory. My first forged motor and I was told their a little noisy but its pretty damn loud lol.
Building my motor I need help on which pistons and rods and which ones to get at a Anthony7515 Engine, Exhaust, Transmission 23 09-21-2014 10:03 PM
i need forged pistons and rods any vendors have any good deals or specials Anthony7515 Want-To-Buy Requests 0 07-28-2014 10:32 PM
12.5/1 Comp Forged Rods and Pistons Darryljr11 Engine, Exhaust, Transmission 1 10-26-2013 07:11 PM
FBM/Arias Forged Pistons FullBlown Forced Induction 35 10-22-2012 07:05 AM
Forged pistons and billet rods paraguin Engine, Exhaust, Transmission 0 09-25-2012 09:55 PM
