Cam timing on Dyno
Hey guys.
I was at the tuner shop yesterday for dyno tune. The cam timing reading is not moving while the car is on dynopack, even after 4 times of flashing. However, it's back to work when we pull the car out for street dyno. Have any of folks here had this issue before? PS. tuning software - ECUtek
Drives: UK GT86
Not seen this on a Dynapack before. There are a number of things that need to happen for the cams to become active, namely clutch pedal not depressed and at a standstill. Oil temp also comes into play.
.: Stealth 86 :.
+1 on what @Kodename47 said
After a flash or ecu reset cams wont activate unless you start car and let it idle for about a minute. Their may be some other conditions as well. If think if you press accelerator or move car before the minute is up the cams wont activate , until the car is turned off then started and let idle for a minute stationary (wheels not turning) |
Drives: Toyota 86 GTS
Your tuner just wasted 100% of that dyno time.
#5 | |
Drives: UK GT86
.: Stealth 86 :.
#6 | |
#7 | |
Drives: UK GT86
I can leave it to idle for a minute and the cams wont be active as the oil temp isn't hot enough. Drive for 30 seconds to the end of the road and idle again and they'll usually start to work.It's worth noting that I will allow for the engine to idle for a minute on a cold flash, however if the engine is warm I wait until the cams show signs of movement. If you're using ECUtek then some AVCS parameters log to the nearest degree, others to 1 dp.
.: Stealth 86 :.
We've tried everything like oil temp hits 80 and he tuned quite a lot of twins from before. He did a FR-S that has the same issue with the cam timing but solved after a flash. However, didnt happened on my car
So I was wondering why.
Drives: '15 FRS
"Tooner"
#10 | |
Flash the stock tune back to car cams work = yes = problem with tune cams work = no = problem with car |
#11 |
#12 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've had one car last year that was similar. Would not set the cams no matter how long you idle. What we found is that if you take it up to road speeds on the dyno and then decel in 3rd gear a few times, they would then set. Not sure exactly why, certainly nothing about the setup as it was identical to a dozen others.
#13 | |
Drives: '15 FRS
My MoTeC programming doesn't have this problem, however. The cams move every time, lol |
#14 |
Mine always work flashing cold. But may not activate after flashing hot and idling for a couple minutes until a restart.
| Cam timing adjustments without dyno | StormTrooper | Software Tuning | 17 | 02-19-2014 04:16 PM |
| POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) | stevo_12v | Engine, Exhaust, Transmission | 10 | 12-19-2013 02:02 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
