Old 04-29-2016, 10:55 AM   #1
aruxe
Cam timing on Dyno
Hey guys.
I was at the tuner shop yesterday for dyno tune.
The cam timing reading is not moving while the car is on dynopack, even after 4 times of flashing.
However, it's back to work when we pull the car out for street dyno.
Have any of folks here had this issue before?
PS. tuning software - ECUtek
aruxe is offline   Reply With Quote
Old 04-29-2016, 11:00 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not seen this on a Dynapack before. There are a number of things that need to happen for the cams to become active, namely clutch pedal not depressed and at a standstill. Oil temp also comes into play.
.: Stealth 86 :.
Kodename 47 DJ:
FRS Justin (04-29-2016)
Old 04-29-2016, 11:10 AM   #3
steve99
Drives: FT86
+1 on what @Kodename47 said
After a flash or ecu reset cams wont activate unless you start car and let it idle for about a minute.
Their may be some other conditions as well.
If think if you press accelerator or move car before the minute is up the cams wont activate , until the car is turned off then started and let idle for a minute stationary (wheels not turning)
Old 04-29-2016, 07:50 PM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Your tuner just wasted 100% of that dyno time.
The Following 4 Users Say Thank You to Wayno For This Useful Post:
CSG Mike (05-03-2016), DBW (05-16-2016), nickmerronesucks (05-18-2016), wparsons (07-28-2016)
Old 04-30-2016, 04:01 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's not entirely true. I've seen the cams become active immediately after a flash if the conditions are met. Once you've done a dyno pull you can just flash, clear codes and fire it up and go again. Also hitting the throttle won't necessarily prevent its calibration, once back at idle it will sort itself out again.
.: Stealth 86 :.
Kodename 47 DJ:
steve99 (04-30-2016)
Old 04-30-2016, 05:26 AM   #6
steve99
Drives: FT86
Yeah all true, but if you do the start idle for a miniute you seem to be good good to go every time.
Old 04-30-2016, 11:17 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably in your climate I can leave it to idle for a minute and the cams wont be active as the oil temp isn't hot enough. Drive for 30 seconds to the end of the road and idle again and they'll usually start to work.
It's worth noting that I will allow for the engine to idle for a minute on a cold flash, however if the engine is warm I wait until the cams show signs of movement. If you're using ECUtek then some AVCS parameters log to the nearest degree, others to 1 dp.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
steve99 (04-30-2016), wparsons (07-28-2016)
Old 04-30-2016, 04:30 PM   #8
aruxe
We've tried everything like oil temp hits 80 and he tuned quite a lot of twins from before. He did a FR-S that has the same issue with the cam timing but solved after a flash. However, didnt happened on my car
So I was wondering why.
Old 04-30-2016, 09:31 PM   #9
VitViper
Drives: '15 FRS
"Tooner"
VitViper is offline   Reply With Quote
The Following 2 Users Say Thank You to VitViper For This Useful Post:
BRZoomTX (05-06-2016), CSG Mike (05-03-2016)
Old 04-30-2016, 09:37 PM   #10
steve99
Drives: FT86
Flash the stock tune back to car
cams work = yes = problem with tune
cams work = no = problem with car
Old 04-30-2016, 10:28 PM   #11
steve99
Drives: FT86
Originally Posted by VitViper View Post
"Tooner"
Nah wrong TUNA
Actually canned TUNA
FRS Justin (05-06-2016)
Old 05-01-2016, 07:13 AM   #12
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've had one car last year that was similar. Would not set the cams no matter how long you idle. What we found is that if you take it up to road speeds on the dyno and then decel in 3rd gear a few times, they would then set. Not sure exactly why, certainly nothing about the setup as it was identical to a dozen others.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 05-03-2016, 02:23 AM   #13
VitViper
Drives: '15 FRS
Had similar behavior happen, immediately after flashes, when doing road driving. No amount of deceling would fix it -- a power cycle would though.
My MoTeC programming doesn't have this problem, however. The cams move every time, lol
The Following User Says Thank You to VitViper For This Useful Post:
Old 05-03-2016, 03:25 AM   #14
Wayno
Wayno's Avatar
Mine always work flashing cold. But may not activate after flashing hot and idling for a couple minutes until a restart.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
CSG Mike (05-03-2016), FRS Justin (05-06-2016)
Cam timing adjustments without dyno StormTrooper Software Tuning 17 02-19-2014 04:16 PM
POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) stevo_12v Engine, Exhaust, Transmission 10 12-19-2013 02:02 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
