CANADA Canada
Old 04-13-2016, 10:47 AM   #1
pizzahead20
Drives: 2013 Subaru BRZ (6MT, WRB, S-T)
Squeaking noise when depressing clutch
Wondering if anyone has a problem with a squeaking sound when depressing the clutch?
This is what it sounds like. It's not my car, but it's exactly this:
It's an issue with the throwout bearing. Looks like some people have had luck getting it fixed under warranty in the US:
http://www.ft86club.com/forums/showt...t=56882&page=7
Does anyone with a BRZ have the same issue in the GTA and was able to get their Subaru dealer to fix it under the 5 year powertrain warranty? I'm at 65k km so I'm out of the bumper to bumper warranty. I've been to my dealer and asked and they specifically said the the thorwout bearing is not part of the powertrain warranty.
pizzahead20 is offline   Reply With Quote
Old 04-13-2016, 12:32 PM   #2
sIowbrz
Drives: 2015 brz
So i guess you were the guy at markham subaru earlier
sIowbrz is offline   Reply With Quote
Old 04-13-2016, 05:18 PM   #3
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I remember the throwout bearing comes pre-greased and is like a 60 dollar part, got mine from Markham Subaru when I upgraded to the STI clutch assembly at 10k just to be safe.
FWIW I also changed the clutch fluid to ATE Typ 200 Brake Fluid and the gearbox oil to Eneos Gear Oil. Everything is super smooth afterwards.
Just had a clutch bleed and gerabox oil changed again at 25k with the same stuff and it's smoother than ever. Maybe try this first?
BTW I also want to mention when I got the car new, one night the temperature fell to -7C and the clutch fell kinda stiff and funny. Never had that happened again after the clutch work and still operates normally even at like -15C.
krayzie is offline   Reply With Quote
Old 04-13-2016, 05:59 PM   #4
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Do you hold the clutch in when stopped at a light?
Jrdad is offline   Reply With Quote
Old 04-14-2016, 01:00 PM   #5
wparsons
wparsons's Avatar
I have a squeak in mine, but it's definitely something in either the pedal assembly or clutch slave. It only squeaks while the pedal is in motion, not if you hold it in any specific position.
If it's the throwout bearing you'll hear it constantly whenever the clutch is depressed and the engine is running.
*edit* - mine sounds exactly like the video.
flickr
Old 04-14-2016, 01:34 PM   #6
http://www.ft86club.com/forums/showthread.php?t=56882
http://www.ft86club.com/forums/showthread.php?t=49020
Old 04-14-2016, 11:14 PM   #7
pizzahead20
So I spoke to another service manager at another Subaru dealer who was being a lot more helpful and transparent than Markham Subaru and he confirmed with me that for Subaru, the throwout bearing is NOT part of the powertrain/major component warranty, but IS part of the 3 year/60k km bumper-to-bumper warranty. Interestingly (and very annoyingly), apparently Scion/Toyota has been honouring the warranty and fixing throwout bearing issues for the FRS. Not sure under which warranty Scion/Toyota is fixing the issue with. Very disappointed in Subaru Canada.
My transmission and gear box are still fine. feels the same as it was when I first got the car as well. but of course 1st to 2nd feels a little "crunchy" and unsmooth as with all BRZ/FRS. Out of curiosity, how much was your STI clutch assembly?
I used to do that for a short while, but I stopped doing that now.
Well I brought it to the dealer and a private shop I go to and they both said it's coming from the engine bay and it is the throwout bearing.
thanks, I saw these threads already, but want to know if anyone in the GTA has had luck getting their Subaru dealers to fix this issue under the powertrain warranty.
Old 04-14-2016, 11:27 PM   #8
sIowbrz
Drives: 2015 brz
Lol disappointed at subaru canada... the manager at markham subaru told you straight up release bearing is not cover under the 5yr/100k... but it was for 3yr/60k which you car was at 65k lol your mad cause subaru wouldnt cover cause you pass 3yr/60k
Old 04-14-2016, 11:54 PM   #9
DM7
Drives: '13 FR-S Argento
From my experience the squeak is not from the TOB but rather from the pivot points on the clutch release fork.
I had forgotten about this post. I tinkered for a while just jiggling the fork to get it to quit squeaking but it kept coming back. Then, out of desperation, I moved the slave out of the way and removed the dust boot from the bell housing. Feeling around in there I discovered I could just barely get my finger on the main pivot.
I smeared a little gob of grease in there as best as I could and poof, squeak eliminated.
I still say transmission should be dropped to really get in there, inspect everything, and do it right but this'll do for now.
My Civic had the same noise. Big glob of urea grease on both pivot points of the clutch release fork solved it.
My FR-S made that noise a few times last summer so I'm going to do the same this year.
Since you are out of the B2B warranty I would recommend that you give lubricating both pivots on the clutch release fork a try. It will cost very little as long as the transmission is not removed to do this.
Even Car and Driver had the TOB changed in their long term BRZ unnecessarily.
"Around 21,000 miles, the clutch pedal developed a squeak that proved particularly difficult to eradicate. It was temporarily fixed by separating the transmission from the engine and fitting a new throw-out bearing, plus lubing the various components, but the squeak returned at 34,000 miles. This time the dealer installed a new master cylinder and additional lubrication to make it go away, all under warranty."
http://www.caranddriver.com/reviews/...wrap-up-review
Dealers are likely changing the TOB to justify the labour required to remove the transmission as a warranty repair. Ignore the part about a new master cylinder, I have a feeling the dealer just needed a reason to bill the lube job as a warranty repair again.
DM7 is offline   Reply With Quote
Old 04-15-2016, 12:13 AM   #10
krayzie
Drive From Home
krayzie's Avatar
Bought from Japanparts. It's basically the clutch disc + clutch cover / pressure plate. After shipping and taxes it was about 800 bucks, and this was before the Canadian currency crashed. Paid another 60 bucks for the throwout bearing + 400 bucks to get everything installed.
You know when I got home today I turned off the car, and stepped on the clutch a few times to see if I can hear the same sound near the bottom of the stroke, and indeed it's there dam!
Old 04-15-2016, 11:24 AM   #11
wparsons
wparsons's Avatar
100% this. The dealership isn't 100% wrong, since it's related to the TOB, but the bearing itself isn't shot. If the bearing was shot you'd hear a worn bearing noise anytime you press on the clutch pedal.
flickr
Old 06-21-2016, 09:16 AM   #12
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Did u end up fixing this up?
bhbnuckle is offline   Reply With Quote
Old 10-16-2016, 10:26 PM   #13
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
i hate to bring a thread back from the dead. but I think my TOB or something else gave out today.
I have had some squealing at idle on cold starts for a few days now, but nothing too crazy, and it would go away once the car warmed up. Today I was pulling into a parking lot and accidentally let out the clutch too fast, lurching the car. Instantly there was tons of squealing from the clutch, and a puff of smelly clutch-smoke coming from under the hood. I parked and shut it down.
Came back out of the grocery store and started it up again, and it was squealing just a bit at idle with the pedal out, accompanied by a bit of a rattling sound, but it squeals non-stop with the pedal in. Driving seems fairly normal; there's no noise from the clutch at speed, and it doesn't feel like it's slipping if you step on it. But the engagement point feels different now, and there's tons of noise every time you so much as rest your foot on the pedal.
I was testing it in my driveway after I got home, and there was about 3 or 4 times where I would push the clutch pedal in and the car would stall out completely.
TOB?
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 10-16-2016, 10:59 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by SLVRSRFR View Post
TOB?
Yup.
Squeaking noise from the steering ScionFR-S Issues | Warranty | Recalls / TSB 22 02-09-2018 05:37 PM
Squeaking noise in the engine bay. TakShing Issues | Warranty | Recalls / TSB 1 10-27-2014 01:51 AM
Squeaking noise from wheel oinkoinkpig Issues | Warranty | Recalls / TSB 8 04-26-2014 11:10 AM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
Squeaking Noise From Steering Wheel tonytduc Scion FR-S / Toyota 86 GT86 General Forum 4 01-28-2013 07:58 PM
