Drives: FRS
High quality stem valve for Rays wheels?
Well, I purchased a set of Rays wheels used and they did not come with any OEM Rays stem valve. Is there any quality aftermarket/JDM stem valve that you guys would recommend? Not a huge fan of the regular rubber ones
Drives: 2014 FRS
I have set of oem rays valve stem that i didnt use from my set of wheels.
I can sell them. pm me an offer |
Drives: FRS
i guess if you really want rays,
my te37 came with rays valves but i ditched them to use my factory tpms valves.. just thought i'd throw it out there as an option
'14 Scion FRS
Tein Flex TE37 |
Drives: Subaru BRZ Limited
I got some brand new from when I bought my wheels. PM me and make an offer. They are new in the package still.
Sent from my Nexus 5 using Tapatalk |
Drives: FRS
depending on which wheel you have, chances are you can just use valve stems for an RPF1 fine
| The Following User Says Thank You to 8R6 For This Useful Post: | JazzleSAURUS (05-05-2016) |
#6 | |
Drives: 15 BRZ LTD, 05 FXT
They fit great in: Enkei RCG4, 04 STi BBS, OEM 05 FXT wheels, 02 WRX BBS Prodrive Options, 2000 RS GC 5 spokes. They tend to run around $40 a set, don't leak, and are available in black.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | 8R6 (05-05-2016) |
| Leaking valve stem - Warranty? | Eldari | Issues | Warranty | Recalls / TSB | 6 | 02-02-2016 06:15 PM |
| Works Valve Stem & RS-R Lug Nuts | xDBOYx | Wheels and Tires | 7 | 11-29-2014 05:23 PM |
| Questions about Valve Stem Fitments | Stayreal | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-26-2014 04:25 PM |
| Are your valve stem caps safe? | qqzj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 10-18-2013 01:32 AM |
| Can this valve stem be rebuilt? | ayau | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 12-24-2012 02:57 AM |
