Old 07-02-2012, 04:05 AM   #1
motofan
Drives: 10 VW GTI
Anyone thinking of oil-extraction (from the top) oil changes?
I think I read from somewhere that Mercedes and some other European manufactures put their oil filters on the top, and they use pumps to extract oil from dipstick hole, as their standard oil change service procedure.
I wonder since this car has a top mounted oil filter, is it OK not to go under the car for the oil change?
motofan is offline   Reply With Quote
Old 07-03-2012, 06:32 PM   #2
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Perhaps, but I think this is more trouble than it's worth. Buy a set of ramps and a Fumoto valve and it should be easy and painless. This post has some good advice:
http://www.ft86club.com/forums/showthread.php?t=10007
Old 07-03-2012, 08:12 PM   #3
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Thats like a dentist reaching up my ass to pull a tooth. Other than charging more, what's the point?
GenkiElite is offline   Reply With Quote
Old 07-04-2012, 01:32 AM   #4
fenton
Not sure who you are replying to but technically taking the oil from the top would be like reaching into your mouth to pull a tooth not your ass?
It would be less time (and easier) using a pump through the dipstick but the real question is how much can we pull out that way.
My friend does it with a pump and he gets all but about .2 liters of the engines oil capacity, which i feel is pretty good.
fenton is offline   Reply With Quote
Old 07-04-2012, 10:01 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not sure it's quicker though. Oil change bays are designed for the purpose. Maybe they weren't smart enough to leave a hole for the drain plug o underbody panels need to be removed on the Benz?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-04-2012, 10:24 AM   #6
mach330
Drives: Ultramarine frs
I've dune this all the time with my bimmers. I'm glad they put the oil filter on top too on the fed/brz. It's much easier to change and clean without ever having to Jack up a car. I do this every other oil change.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 07-04-2012, 10:34 AM   #7
jonnyboy
Drives: GTS 86 6AT
I do this every 5000km for my cooper S, in between the recommended 20,000km service intervals (to long!). It is very simple and a good alternative if you don't have a ramp. But I doubt it is quicker as you have to be there while the oil is being pumped out and I probably get about 80% of the oil out, but I think its better than not doing an oil change. Anyway, I get the dealer to do the proper oil change at the recommended intervals to really flush everything out.
jonnyboy is offline   Reply With Quote
Anyone else thinking about the door stabilizer? russv Cosmetic Modification (Interior/Exterior/Lighting) 35 04-10-2013 12:09 PM
thinking of car finance Allan.manta90 Off-Topic Lounge [WARNING: NO POLITICS] 7 06-25-2012 01:00 AM
Almost time for my first car, here is what I was thinking YoshiMike13 Other Vehicles & General Automotive Discussions 15 06-21-2012 11:27 AM
Any 1 thinking that they may not get either car? Shora BRZ First-Gen (2012+) — General Topics 40 04-06-2012 09:59 PM
what color are you thinking of getting? stlgrym3 Scion FR-S / Toyota 86 GT86 General Forum 3 02-09-2012 10:53 PM
