Old 04-08-2016, 12:56 PM   #1
Kendallkab
Drives: Black MT LMT BRZ
dm6 wideband and injector question
I'm going to sound dumb asking this but i don't care. I'm still in the learning phase of things and trying to get a list of everything I'll need to purchase to FI my car.
Question: I'm on FT86 speedfactory looking at the add ons and I don't know if I should add a dm6 wideband because I don't know what it is and can't find anything on it. I also don't know if I should get the 1000cc injectors if my goal is 300whp with a custom 8 - 11 psi tune on 93 oct if possible. I need someone to share there knowledge with me.
My mind is set on the FBM base kit GT2871R.
Also would black coating trap heat or is it like a ceramic black?
Kendallkab is offline   Reply With Quote
Old 04-09-2016, 10:25 AM   #2
Ashikabi
Ashikabi's Avatar
For 300hp you shouldn't need 1000cc but probably their lowest upgrade. If you think you nugget want more power later just get the 1000cc so you don't have to upgrade later. I think I just saw someone in classifieds selling some, might be worth a look. Dunno about black coating. Call ft86 and ask I guess
Old 04-09-2016, 01:19 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The black coating of non thermal paint wouldnt do much if anything at all. Any kind of black coating would be ceramic.
The specific dm6 wideband may be light on info, but basically it allows you to monitor your AFR lambda very closely to see if you get any lean spikes, running too rich, inconsitiancies and what not. Generally seen as a DD support item.
Old 04-09-2016, 03:44 PM   #4
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
You don't even need injectors at that power level on pump gas.
I'm partial to Innovate over PLX. Take a look at the Innovate SGC-1. It's a boost controller and gauge, and wideband gauge all in one. A friend here locally runs one in his FR-S.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 04-09-2016, 04:57 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Get what your tuner said to.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-09-2016, 08:26 PM   #6
Luftwaffel
Boost Creep
Luftwaffel's Avatar
If we all did that, we'd all have whoever has the highest profit margin.
Old 04-10-2016, 01:20 PM   #7
Kendallkab
All in one sounds perfect. Thank you I'll be sure to take a look
NOOB wideband AFR question Flat_4_Life Forced Induction 5 03-06-2016 04:00 PM
Noobie injector install question DAN_BRZ Engine, Exhaust, Transmission 0 04-15-2015 11:36 AM
Injector size question boostedbrz Forced Induction 1 02-14-2015 05:10 AM
wtb injector aem wideband kcam86 Want-To-Buy Requests 0 04-13-2014 08:46 PM
Question about wideband and software tuning post_break Software Tuning 5 04-08-2014 09:53 PM
