Old 03-03-2016, 08:55 PM   #1
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Question NOOB wideband AFR question
So I plan on installing a wideband AFR gauge and was wondering about orientation of the sensor on the down pipe. Does I mater if I put the sensor before or after the o2 sensors?
Flat_4_Life is offline   Reply With Quote
Old 03-03-2016, 09:09 PM   #2
Trust86
Drives: 2016 Halo FRS
18 inches away from exhaust ports on N/A
36 inches away from turbo if boosted
Mount before cats if you have any or go catless
Mount AFR sensor at a 10 degree angle minimum
AEM recommendations
Trust86 is offline   Reply With Quote
Old 03-03-2016, 09:15 PM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The distance varies by car/manufacture though but a good rule is somewhere between 16"-40" away from the engine... far enough away where you don't kill the sensor (overheating.) If your have a turbo place it further back on the downpipe for the same reasoning.
You can place it around the upstream 02 sensor. Just know, if it is behind any of the catilyic converters they will interfear with the readings. Also place the sensor on the topside of the exhaust so if the car sits, condensation will not sit on the sensor. 10-2 O'Clock postions work best depending on piping design.
Old 03-03-2016, 09:22 PM   #4
Flat_4_Life
Thanks guys, I forgot to mention I'll be FI
Old 03-03-2016, 09:33 PM   #5
Flat_4_Life
Also just out of ceriosity, did I see somewhere that the secondary o2 sensor is a widband?
Old 03-06-2016, 04:00 PM   #6
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Secondary isn't a wide band. I used the secondary spot until I could get a new bung welded in. I've got it between the primary and secondary sensors now.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Noob question about OFT nyfries Software Tuning 4 12-09-2014 12:07 AM
Question about wideband and software tuning post_break Software Tuning 5 04-08-2014 09:53 PM
noob question here about f.I.... zimzum Forced Induction 7 03-06-2014 04:24 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
