Old 04-07-2016, 04:39 AM   #1
Tofu-86
Drives: 2015 WRB BRZ Limited
The cracking shounds
Am I the only that is obsessed with the exhaust's cracking sounds? Whenever you lift off in a V8 F-type/ AMGs you get that popping/ cracking sounds which is just strong pornography for me.
At first I thought any aftermarket exhaust on the twins can make it happen but clearly I was wrong, right now I have a borla catback and it only pops when I rev the engine while starting the car. Does anybody have that sound on any other exhaust setup with the twins?
Tofu-86 is offline   Reply With Quote
Old 04-07-2016, 06:35 AM   #2
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
There's a whole thread dedicated to it:
http://www.ft86club.com/forums/showthread.php?t=61069
Looks like you'll need an OpenFlash Tablet with a modified tune, as well as a catless header and catless/high-flow front pipe.
NLSP is offline   Reply With Quote
Old 04-07-2016, 08:39 PM   #3
zberz
Drives: 2015 Lightning Red BRZ
People are tuning their cars so they backfire? I don't think that's good.
sent from my phone using black magic
zberz is offline   Reply With Quote
Old 04-07-2016, 09:12 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Well we don't know long term effects of running the tune and cutting timing off throttle I ran the tune edit as well as others and we haven't blown a cat out yet one guy has had it for over 10,000 miles. The only downside would be if you have an actual muffler you can kiss any muffler packing material good buy it'll burn and blow out anything in there making your car much louder
You really minimum just need a catless header or muffler delete, it pops and crackles regardless, however doing it on a stock car risks destroying the muffler. The tune edit is super simple in romraider, I also noticed it completely ruins your gas mileage the more you do it, in fact it becomes so predictable you can modulate it off throttle.
Yes you have to edit the tune, specifically just one table to cut timing in ignition map B, minimum you have to have an Openflash tablet or tactrix cable and know how to edit the rom in romraider.
[ame="https://www.youtube.com/watch?v=c2VgspN8oBQ"]Subaru BRZ JDL UEL rev - YouTube[/ame]
^That's what it sounds like catless, my car sounded more like popcorn with two cats in my exhaust and essentially no muffler. After a week of using it, it loses novelty
Old 04-07-2016, 09:25 PM   #5
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
One of my favorite sounds: [ame="https://www.youtube.com/watch?v=RfHOU_x5Ovg"]Cosworth Stage 1.2 - Scion FR-S/Subaru BRZ Exhaust - YouTube[/ame]
sly is offline   Reply With Quote
Old 10-11-2016, 01:16 AM   #6
WHITEBUUURRZZ
Drives: 2013 BRZ 6mt limited
I have a tomei 60s on my BRZ and it just burbles when letting off or downshifting. There is a small pop sometimes when going down or up to 2nd, not very loud. Everything else stock
WHITEBUUURRZZ is offline   Reply With Quote
Old 10-11-2016, 02:32 AM   #7
ryoma
ryoma's Avatar
your best bet is to remove both the cats in your exhaust system but then it will be pretty loud
Old 10-11-2016, 06:07 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I had a muffler delete and never heard pops or bangs or anything. Then I gutted the front pipe cat and loaded a stage 1 OFT tune, and I got a few muffled noises. Once I gutted the header and loaded stage 2, I got a lot more pops and over runs. It's still not like altering the tune like above, and it is not predictable but it happens at odd times. Sometimes I get big loud pops that make people jump sometimes it's just burbles, other times it's a small pop.
I thought it'd happen on lifting off the throttle pulling hard, but sometimes I'm on steady low throttle and lift off to shift and get pops. The harder I'm pulling the less I seem to get the noises.
Old 10-11-2016, 06:52 AM   #9
Lantana frs
Drives: 13 frs red
Remove the nuts from one side of the header. She oughta pop real good then.
Lantana frs is offline   Reply With Quote
Old 10-11-2016, 07:48 AM   #10
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Sometimes when I shift from first to second after just cruising without going into boost heaps, and then give it a boot it goes BANG!!!! Blastpipe lyfe
COO86L is offline   Reply With Quote
Old 10-11-2016, 07:58 AM   #11
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I don't ever get loud bangs, but I'm not sure I'd want to...
However, my single exit delete will give some burbles, crackles and the occasional pop on downshifts or when lifting off the throttle. Cheapest way to get this effect and still have a decent exhaust note.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-11-2016, 04:46 PM   #12
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
Can confirm. Mine does this. It's not excessive, but it happens, and I get glee every time.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 10-11-2016, 05:41 PM   #13
strat61caster
strat61caster's Avatar
I've driven two cars that do this from the factory, Fiat and Mini. Seems like it's almost becoming standard on any 'performance' car being offered these days from Ford to Mercedes.
Here's the Mini with a 'factory' JCW catback, relevant stuff starts at 30s in.
[ame="https://www.youtube.com/watch?v=V_a5x9uUvHc"]JCW Tuning Kit | Exhaust Sound | VERY LOUD | Mini Cooper S F56 - YouTube[/ame]
ineedyourdiddly
Old 10-11-2016, 05:58 PM   #14
humfrz
WOW !........ how easily some of us are entertained ......
humfrz
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 08:59 PM
Paint Cracking? Heero Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 01-29-2014 12:53 PM
Cracking on brake pad (CL RC6E) speedy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-16-2014 01:13 AM
exhaust cracking and leaking driver01 Engine, Exhaust, Transmission 80 09-17-2013 03:25 AM
Keep dash board from CRACKING Howardwei Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 22 09-06-2013 06:59 PM
