Old 04-04-2016, 05:11 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
15mm h&r spacers tq specs?
I recently purchased h&r spacers second hand off somebody and was wondering if anybody has the tq specs for the bolts that connect the spacers to the hubs. I would also like to know the tq specs for the bolts that hold the wheels to the spacers. I went 90ft/lbs on both. Is that where they are suppose to be?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-04-2016, 05:19 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I think its same as factory wheel spec so 90-100ft/lbs should be good.
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
Astroboy (04-04-2016), Leonardo (04-04-2016)
Old 04-04-2016, 05:20 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
Factory say 89. So I went 89 on the spacers to hub, and 90 on the wheels
The Following User Says Thank You to Astroboy For This Useful Post:
go_a_way1 (04-04-2016)
Old 04-04-2016, 05:21 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You should be good then. Just check wheels again in 100km's to be safe.
H&R 15mm Spacers +extended studs Jav Wheels and Tires 2 06-09-2019 05:27 PM
H & R spacers 5/15mm, ARP studs jack43 Wheels and Tires 4 11-21-2014 06:04 PM
10 or 15mm spacers on 17x9 +42 Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-03-2014 05:23 PM
FS: 2 Ichiba 15mm spacers sw20kosh Brakes, Suspension, Chassis 3 08-04-2014 01:20 PM
FS NJ: Poweredbymax 15mm Spacers Doobster Wheels and Tires 2 03-31-2014 09:55 PM
