Old 10-29-2014, 09:24 AM   #1
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
10 or 15mm spacers on 17x9 +42
This beast needs some camber bad... I'd like to find some 10mm bolt-on spacers but i cant find ANYTHING. a coworker of mine has some 10mm bolt-on project kiks or something on his evo but i've yet to find them again... I just want to get 1.7 or 1.8* of camber up front.
Does anyone know where to get these? I'd much prefer to not have to press studs so bolt-on is prefered but would you guys go with a 10 or 15mm spacer either way...
here is how the car sits now... i will have hotchkis 1" drop springs on it when i put spacers on it.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-29-2014, 10:01 AM   #2
wparsons
wparsons's Avatar
Replacing the front studs isn't hard at all, and can be done in a driveway with hand tools.
Rears need the hubs pulled from the upright to get the longer studs back in.
flickr
Old 10-29-2014, 10:44 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
You would probably get better answers in the wheels section.
1974 TA22 Celica
2013 86 GT
Old 10-30-2014, 07:31 AM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
I'm confused by your question.
Are you under the impression that wheel spacers somehow change the amount of camber in the suspension?
Old 10-30-2014, 11:58 AM   #5
Gunman
Drives: 2019 Mazda Miata RF
He needs to gain space between the front strut, and tire, so he can use camber bolts to add more camber.
Gunman is offline   Reply With Quote
Old 11-03-2014, 03:02 PM   #6
Roadcone
StreetKart
This. I have almost zero clearance between the tire and strut.
Old 11-03-2014, 04:22 PM   #7
jvincent
jvincent's Avatar
b2autodesigns has some decent looking bolt on spacers.
I was considering them when I was looking at new wheels. Turns out the ones I got clear the OEM spring perch by grand canyon-esque 4mm even with camber maxed out.
Old 11-03-2014, 05:11 PM   #8
wparsons
wparsons's Avatar
I'm at about 1-2mm of clearance with 17x8 +45 and -2* of camber.
flickr
Old 11-03-2014, 05:23 PM   #9
gramicci101
Off Topic
A 10mm spacer would take you to 17x9+32, which would protrude a fair amount from the wheelwell. For example, here's a 17x9+30: http://www.ft86club.com/forums/showthread.php?t=7533
F/S BNIB H&R 15mm Wheel Spacers jammz Wheels and Tires 1 04-27-2019 08:36 AM
H & R spacers 5/15mm, ARP studs jack43 Wheels and Tires 4 11-21-2014 06:04 PM
FS: 2 Ichiba 15mm spacers sw20kosh Brakes, Suspension, Chassis 3 08-04-2014 01:20 PM
(SOLD) FS: (2) 15mm, (2) 25mm B2 Auto Wheel Spacers ericmpena Wheels and Tires 9 06-17-2014 11:31 AM
FS NJ: Poweredbymax 15mm Spacers Doobster Wheels and Tires 2 03-31-2014 09:55 PM
