Old 04-02-2016, 12:28 AM   #1
Wyattkb
Drives: 2014 Whiteout FRS
Strut Hitting Fender Well, Help!
So I after I installed my camber plates and got an alignment I started hearing a loud clunk when going up curbs into driveways. Sounded like something was loose and hitting. Just got the car up on jack stands and noticed the strut/coil was rubbing the inside fender well which I am assuming is causing the noise. I can feel/hear it on the driver side predominantly but it also shows wear on the passenger side.
I had them set camber to -3.3 in the front.
Anyone have any idea what I did wrong or could be causing this?
Here are some pics of what I saw.
Wyattkb is offline   Reply With Quote
Old 04-02-2016, 12:53 AM   #2
whataboutbob
AutoX-10/10ths every run
Are you still on factory struts? It looks like there isn't enough room to get -3.3 without contact (obviously). You might try using camber bolts and backing off the camber up top some.
Build thread:Here
Old 04-02-2016, 01:06 AM   #3
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Well there seems to be too much offset in the camber plate allowing the strut to contact the inner walls. With OEM type coil and perches, there isn't a whole lot of space there for tilting the alignment over by upper mounts, so the only solution will be to back off the camber till it clears the inner walls at compression.
Cusco has a extended lower arm now, which can be used to gain camber by extending the bottom king-pin location rather than at the top. Which moves the assembly outward rather than inward too, if you need to keep -3.3 or more.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
The Following User Says Thank You to Moto-P For This Useful Post:
whataboutbob (04-02-2016)
Old 04-02-2016, 01:35 AM   #4
Wyattkb
I am still on factory struts.
I have camber bolts in the upper perch slot as well.
No one else has this problem on stock struts? or am I only the only one with stock struts at that much camber?
So I guess the solution is to just dial back the camber?
Old 04-02-2016, 01:40 AM   #5
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Nope, tub the front and add more camber.
Come on, man...
sdemo is offline   Reply With Quote
The Following 2 Users Say Thank You to sdemo For This Useful Post:
Calum (04-02-2016), TRAKRAVN (04-02-2016)
Old 04-02-2016, 02:03 AM   #6
Wyattkb
Come on, man...
lol my setup is not that aggressive.
Old 04-02-2016, 01:11 PM   #7
8R6
8R6's Avatar
Drives: FRS
what wheel/tire specs are you running? just curious as to why you need -3.3 while on stock struts instead of coilovers
8R6 is offline   Reply With Quote
Old 04-02-2016, 01:23 PM   #8
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Did you install this yourself or have a shop professionally install this? If the shop installed this without the proper alignment....horrible job.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 04-02-2016, 04:35 PM   #9
Wyattkb
Stock wheel size, Hankook Rs3. I am running that amount of camber per what CSG recommend for my track days.
I had installed them myself but had a shop do the alignment. I will be going tomorrow to have the alignment redone, maybe they can get more camber from the bolts and reduce the amount set from the plates.
Sent from my SM-G925V using Tapatalk
The Following User Says Thank You to Wyattkb For This Useful Post:
8R6 (04-04-2016)
Old 04-03-2016, 07:53 PM   #10
Wyattkb
Update
I went to a recommended alignment shop today to get everything setup again because I installed adjustable toe arms. Ended up being the previous shop did not even use the camber bolt adjustment and just used the camber plates maxed out.
Car has a great alignment now done properly.
-3.2 Camber front
0 toe front,
-2.2 camber rear
1/16 total toe rear
6.8 caster
8R6 (04-04-2016)
Hitting rev limiter with supercharger xsnapshot Forced Induction 50 01-14-2016 11:51 PM
feel like hitting the cayons today almedarj Southern California 0 01-12-2014 10:38 AM
Wheel hitting tie rod? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-16-2013 05:17 AM
BRZs hitting Tampa, FL! FLHC BRZ First-Gen (2012+) — General Topics 63 07-24-2012 10:20 PM
First newspaper reviews hitting the web.... Sport-Tech BRZ First-Gen (2012+) — General Topics 12 05-12-2012 09:32 AM
