Drives: 2017 BRZ - Dark Grey Metallic
How do I unplug tweeters?
I'm trying to install the OEM Audio Plus... And I'm failing at step 1.
I've got the grills out of the dash easily enough, but can't for the life of me figure out how to disconnect the tweeter plug. I've tried both tweeters, I've pressed the moving white tab down, I've jiggled it. I studied the inside of my new tweeter connection. I've pulled, prodded and probed these bloody things. Do you need the patience of a rock and the dexterity of a spider monkey? what's the secret? It's 40 minutes later I give up, I've reconnected my battery and put the grills back. I have a splitting headache too. Grrr! Please help! Last edited by softgrip; 04-03-2016 at 05:24 AM. |
TJ Hunt - I saw you and Calvin struggling with the tweeters in your vid (I assume that's yours). How did you get them out?
Drives: 2015 BRZ
I struggled with mine, too. After some time and some salty language I freed one, giving me the courage to keep trying. I have no idea what magic it took, but I was able to finish the job.
Sent from my iPad using Tapatalk |
| The Following User Says Thank You to ethan160222 For This Useful Post: | softgrip (04-03-2016) |
Drives: 2016 Halo FRS
you might be holding the plug from freeing itself lol. Just try pushing down on only the tab, touch nothing else. Then just pull on the tweeter, don't worry about yanking the wires apart but then again you shouldn't have to pull that hard.
| The Following User Says Thank You to Trust86 For This Useful Post: | softgrip (04-03-2016) |
#5 | |
Not being able to remove the grill from the tweeter beforehand doesn't help either - everything is cramped in the corner of the dash and window. I'll try again tomorrow. |
| The Following User Says Thank You to softgrip For This Useful Post: | Trust86 (04-03-2016) |
| Shrill/harsh tweeters | customyota | Electronics | Audio | NAV | Infotainment | 21 | 07-21-2015 02:37 PM |
| Stock Tweeters Available | pd | Audio/Visual, Electronics, Infotainment, NAV | 0 | 07-31-2013 10:04 PM |
| New CDT ES-620 6.5" with crossovers + tweeters | vinh | Audio/Visual, Electronics, Infotainment, NAV | 0 | 07-01-2013 11:52 PM |
| Need help on tweeters | djliquidsteele | Electronics | Audio | NAV | Infotainment | 3 | 05-17-2013 08:13 PM |
| Tweeters that will drop in? | SteveGrillo | Electronics | Audio | NAV | Infotainment | 13 | 02-18-2013 07:17 PM |
