Old 04-01-2016, 02:02 PM   #1
euthqt
Drives: 2013 Scion FRS 10 Series AT
Transmission/Brake Issues?
Hey guys. So my '13 AT FRS has been acting a bit strange... just want to know if anyone else notices any of these issues or if I'm overthinking.
1. My transmission sometimes RPM searches when I shift. For example, if I downshift to 4th gear, my RPM will jump up to let's say 5k (depending obv) and when I apply the gas a little, the rpm dips maybe 300 rpm and then begins to rise. Also, when I am accelerating I sometimes notice the RPM pause (usually around 3K) for maybe half a second then start to rise again.
The transmission also seems to shift pretty hard at times.
2. Also some issues with my brakes? I heard a resonating sound from the rear of the car when stopped in gear (mostly in manual mode). I only notice it when at a complete stop and it almost sounds like a ringing. My brakes also make a decently loud clunking sound when releasing almost like they're stuck and popping off the rotor. I'm not sure for a fact if it's normal but I used to not notice it and it's been going on since it snowed a couple months back.
Thank you in advance guys.
euthqt is offline   Reply With Quote
Old 04-01-2016, 02:35 PM   #2
humfrz
About your brakes, you may have an ABS thing acting up and/or a sticking caliper.
I's suggest you take it into a dealer/brake shop for an evaluation.
humfrz
Old 04-02-2016, 02:32 PM   #3
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
The Trans issue is most likely the torque converter being released and re locking as i have been told. but mine does it too. I would def get the brakes checked out
shaynek is offline   Reply With Quote
Transmission issues SrgtSnuggles Engine, Exhaust, Transmission 7 09-18-2015 11:40 PM
Transmission issues (or me being too anal) Pkush Issues | Warranty | Recalls / TSB 18 12-06-2014 10:43 PM
manual transmission issues. DriftEightSix Engine, Exhaust, Transmission 24 06-10-2013 08:25 AM
manual transmission issues XtremeMaC Engine, Exhaust, Transmission 4 10-10-2012 06:40 PM
Transmission issues... Rob_g Issues | Warranty | Recalls / TSB 13 09-23-2012 07:40 PM
