Old 03-31-2016, 12:59 PM   #1
MacNH
Drives: Scion FR-s
Check Engine Light
I've had the car on the road for about 40 days and the CEL came on. Code said Cam stuff (can't recall actual wording) I bought from a private dealer and will be bringing it to them for servicing (warranty thing)
My question is can I drive it 60 miles to the dealer with the CEL on? I have an 8am appointment tomorrow.
I love the car and I've had fun driving it. Just looking for guidance. I know a lot of people have had the CEL issue here so I hope they can help me.
MacNH is offline   Reply With Quote
Old 03-31-2016, 01:05 PM   #2
Well that is a tough call to be honest. "Cam stuff" could mean a minor sensor issue all the way up to and including you are gonna push a valve through the block (very worst case don't panic).
If the car has not gone into "limp mode" where it restricts revs and power you are probably just fine. Make sure you take it easy though.
Old 03-31-2016, 01:06 PM   #3
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
The CEL isn't a timer for a bomb and your car will explode. It should be fine,just don't drive like a jackass.
Th3rdSun is offline   Reply With Quote
Old 03-31-2016, 01:19 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
if limp mode has been triggered yourncruise control wont work and the vsc/trac light should stay on all the time
Old 03-31-2016, 01:38 PM   #5
MacNH
Drives: Scion FR-s
This is what is happening. I will be limping to the garage that I now know. Thank you for the quick responses. I was tempted to clear the codes but I'm gonna leave that to the dealer
Old 03-31-2016, 02:42 PM   #6
grinerizer
Drives: 2014 Subaru BRZ Limited SWP
Your vehicle is not in limp mode.
If the CEL is flashing, do not drive the vehicle. If it is steady, it is ok to drive.
If you are in the first 3 year 36k from the original date of sale, you have roadside assistance. If it's a Toyota, this part of my reply could be false.
Also, if you are taking it to the dealer, please never clear the code prior. Our computers can see a lot of info behind the code, which most non-oem code readers can not.
Source: I'm a Subaru Service Consultant
grinerizer is offline   Reply With Quote
Old 03-31-2016, 03:50 PM   #7
extrashaky
Drives: 2014 BRZ Limited
So you're saying that when the traction light is on, the A/C and cruise are disabled and the car isn't generating full power, that's not limp mode?
'Cause if it's not limp mode, most of us on the board have been referring to this condition incorrectly for quite a while.
Old 03-31-2016, 04:15 PM   #8
I do not have the manual at work but am pretty sure that is what is written in there someplace. Could also just think that because I have heard it so many times though.
Old 03-31-2016, 05:41 PM   #9
MacNH
Drives: Scion FR-s
I bought this used but got an extended warranty. I did not erase the codes for the exact reason you specified (good guess on my part). I may be limp mode so I will be taking my time getting there and not using the highway. The code was p0018. Crankshaft position. Crankshaft correlation. (Bank 2 sensor A). This not being a Toyota scion dealer is possibly going to make it difficult?
Old 03-31-2016, 08:18 PM   #10
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
I bought this used but got an extended warranty. I did not erase the codes for the exact reason you specified (good guess on my part). I may be limp mode so I will be taking my time getting there and not using the highway. The code was p0018. Crankshaft position. Crankshaft correlation. (Bank 2 sensor A). This not being aToyota scion dealer is possibly going to make it difficult?
Unless you are beyond the 5yr/60K manufacturer's drivetrain warranty, I would strongly encourage you to get it to an Toyota/Scion dealer.
billwot is offline   Reply With Quote
Old 04-01-2016, 08:10 AM   #11
grinerizer
At what point did he mention loss of power and a/c?
Please realize, most of my training and knowledge is Subaru specific.
Every CEL that comes on in a Subaru is accompanied by other lights, and the loss of cruise control. At no point in my years of doing this, has this been referred to as "limp mode." The manual simply calls them "malfunction lamps."
My apologies for any confusion, as I know online terminology can differ from industry terms.
Old 04-01-2016, 11:01 AM   #12
extrashaky
You're right, he didn't. He didn't actually clarify either way. I just assumed the loss of cruise always happened together with the diminished power and loss of A/C, since that's what has happened with mine in the past when I got the U0074 code. I was surprised then that power would be diminished for a communication code, but that wouldn't be the weirdest thing about this car.
Which is why I asked. I learned something new.
Old 04-01-2016, 02:45 PM   #13
grinerizer
There could be a .1 mm leak coming from the gas cap and the CEL can be triggered and you'd lose cruise. This is an example of what can cause the CEL to be steady.
You could have an under-performing alternator causing a misfire (aren't electronic ignitions fun?) which will cause the CEL to flash, and you to lose cruise. Flashing is bad. This is the "limp mode" you speak of. Pull over.
The area I'm in has a lot of retirees, most of my day is spent explaining CELs and telling people to tighten their gas caps. Life is awesome.
Old 04-01-2016, 03:02 PM   #14
DJCarbine
Thupercharged
DJCarbine's Avatar
I had my secondary O2 disconnected and got a similar mode, mine was no cruise/CEL/TC but car had full power and drove as normal. I was running a wideband for a bit to monitor things, everything seemed good in logs
Maybe its like some "half limp" mode like when your prom dates parents walk in to you checking her oil on the family couch
2013 FRS
Vortech V3 11psi
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
