Drives: 2013 Scion FR-S, 2014 Audi S4
Can't figure out my brake (non-)issue
OK, so my first track day went just fine with regards to brakes, I swapped out the stock pads for some StopTech street performance pads right before the event. So, brand new identical pads and this is how my wheels looked after the event:
Driver side ![]() Passenger side ![]() The car did not pull under braking and when I jacked it up both wheels spin freely. I would concur that the passenger side is dragging but, like I said, the wheel spins freely. What else should I be looking at? |
Drives: 2015 Subaru BRZ Series.Blue
Not knowing much about this, could it just be the pads wearing, has it happened again since they were new. If so I have no idea. But if not it might just be them wearing in from being new.
Sent from my SM-N910V using Tapatalk |
| The Following User Says Thank You to j0307 For This Useful Post: | UFO (03-29-2016) |
Drives: Velocity Orange 86 GT
Pedal dance? Ebd can go a bit spastic sometimes and so can the other nannies if allignment is out by a decent amount.
Maybe cuz you didn't break them in?(you worded it like you went straight to the track :iono)
| The Following User Says Thank You to Ashikabi For This Useful Post: | UFO (03-29-2016) |
#5 | ||
. Don't really have anywhere close to me where I can do some spirited driving.Quote:
10 threshold stops from 60 to 10 MPH with only a bit of braking in between and then drove around for 10 minutes with only gentle braking to let them cool down. |
#6 | |
Senior Misanthrope
| The Following 2 Users Say Thank You to kch For This Useful Post: | strat61caster (06-19-2017), UFO (06-19-2017) |
Drives: 2013 Subaru BRZ
More left turns than right could do this.
Modern ABS also have EBD which controls line pressure to each wheel separately. Your brake dust pattern might just be confirming the EBD function is engaged a lot on that particular track. Left front brake is not being applied as hard as the right front, on average. F1 cars aren't allowed to use EBD and lock up the less loaded tire accordingly. EBD gives street cars added safety by utilizing ABS selectively for each of the four wheels. |
| The Following User Says Thank You to Gforce For This Useful Post: | UFO (06-19-2017) |
#8 | |
, and I run with TC off now (as was evident last time out where I did some weed whacking in turn 6); I'm in the big boy's club .
| Need Some Help Please: Brake Issue | zkahle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 02-04-2021 10:53 AM |
| E-Brake issue "clunking noise" when pulling the e-brake while rolling. | Kinzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 06-20-2018 10:14 PM |
| Frs brake issue. | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 01-12-2015 07:28 PM |
| BRZ factory head unit parking brake issue | KevinBRZ | Electronics | Audio | NAV | Infotainment | 0 | 12-03-2014 11:00 PM |
| Cold / Wet weather brake issue? | Ingen | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-29-2012 11:42 AM |
