Old 03-25-2016, 04:30 AM   #1
cawith
Drives: Toyota GT86 6M/T
Talking Possible to tune car a bit louder at idle/low rpm?
Hi guys,
I'm running a catless UEL header with otherwise stock exhaust tuned with OFT stage 2 and some Wayne modifications.
I'm really happy about the sound and volume above 2500-3000 rpm, and I'd rather not have it any louder.
However idle and low rpm sounds a little too tame for my taste when warmed up.
What tune changes can I do to increase the volume of the sweet rumble in the low range and especially at idle, other than increasing the idle rpm..?
cawith is offline   Reply With Quote
Old 03-25-2016, 05:08 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by cawith View Post
Hi guys,
the exact opposite of what the cold start tune tries to achieve. Hold a higher idle speed RPM target, retard the timing more etc.
Old 03-25-2016, 05:12 AM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
There's not much you can do without negatively effecting economy.
Old 03-25-2016, 05:12 AM   #4
Wayno
Wayno's Avatar
What the hell is a cold start tune?
Old 03-25-2016, 05:18 AM   #5
FRSBRZGT86FAN
The quiet cold start EDIT not tune, to get it to not bark and wake up neighbors in the morning with uels and a muffler delete. Where you simply open up romraider and edit timing, the idle speed targets, the maf tables for in gear and neutral....
Old 03-25-2016, 05:28 AM   #6
Wayno
Wayno's Avatar
Which has absolutely zero relevance with engine volume when warm.
Old 03-25-2016, 06:26 AM   #7
steve99
I think your goal will be hard to achieve.
If you retard timing during normal idle your going to have to alter a lot of idle tables and idle stability tables, the car idles at arround +11 degrees and theirs heaps of compensations for stuff like air cond and alternator and likely heaps of other undefined tables that we know nothing about. It likely to have heaps of unknown or undesirable effects and alter economy motor torque likely stalling issues ect.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Aozora.BRZ (03-28-2016), cawith (04-07-2016)
Old 04-07-2016, 07:17 PM   #8
cawith
Thanks for your responses.
I guess I'll have to live with it the way it is, or get a catback that won't drive me nuts.
Old 04-07-2016, 09:31 PM   #9
ryoma
ryoma's Avatar
if you want it louder, just downshift and it will be louder. having a quiet idle is useful when you don't want to attract attention.
Old 04-08-2016, 03:39 AM   #10
WRBrzRX
Drives: runs&drives
very hard to downshift while idling
WRBrzRX is offline   Reply With Quote
The Following User Says Thank You to WRBrzRX For This Useful Post:
kch (04-08-2016)
Old 04-08-2016, 12:11 PM   #11
Teseo
Drives: frs
Rev the engine at 1200rpms and try stay there
Old 04-09-2016, 11:06 PM   #12
FRSBRZGT86FAN
Hi guys,
I'm gonna assume he has everything stock except for uel exhaust wise and I would say just get an axleback that would totally help the idle out
Old 04-10-2016, 12:02 PM   #13
cawith
But axle back would make it very loud all over the rev range with a catless header, wouldn't it?
I've only heard one aftermarket exhaust on a GT86 (I think it was a Perrin). As I remember it, it was very deep and numb sound due to his stock header, but it was still as loud as mine is now while driving.
Old 04-18-2016, 04:55 AM   #14
tracerit
Drives: '13 SSM BRZ Limited 6MT
If I wanted my idle RPM to be at 800 instead of the OFT's 750, do I just change all the 750 values in every table shown below to 800, and change the values that were 775 to 800? Would there be any other tables I'd have to change?
I'd like a higher idle RPM so I can roll off the clutch to get moving easier rather than giving it some gas.
tracerit is offline   Reply With Quote
Is manual louder than automatic? Ymerej Engine, Exhaust, Transmission 15 02-04-2017 06:05 PM
How to make my frs louder Shehadeh Scion FR-S / Toyota 86 GT86 General Forum 30 12-30-2014 09:41 PM
Exhaust too louder in the cabin Junkwipe Engine, Exhaust, Transmission 19 06-14-2014 01:16 PM
Crickets Got Louder... :( JFox Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 06-12-2014 07:42 AM
DIY louder exhaust and intake sw20kosh DIY (Do-It-Yourself) Guides 10 04-14-2013 10:27 AM
