Old 03-23-2016, 06:15 AM   #1
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
114.3 hubs
Hi all,
I want to change my project car over to the bigger beefier bearings, from other Subaru models. I have looked around the 'net and have found various threads regarding doing this. All seem to be 3yrs old or older?
I see Megan do/did supply a set up which gives the 114.3 pcd, but it doesn't look like it gives the bigger bearings?
Can someone please tell me what hubs actually are a straight swap on the rear and what is closes to fit on the front. If I have to buy/make new uprights, fine, but is there anything out there that bolts straight on?
All advice will be gratefully received..
BTW. I need to keep my ABS sensors as I need them for my MoTeC to take care of TC etc.
Nigelr32 is offline   Reply With Quote
Old 03-23-2016, 09:39 AM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I'll have to look at the hubs when I get home but I'm fairly sure that the DSS pro-level axle upgrade allows for the 5x114.3 configuration in addition to the 5x100. Take a look into those.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 03-23-2016, 01:02 PM   #3
Nigelr32
Thanks for the reply. I already have the 600HP DSS shafts as I thought they will do just fine. I am sticking with the little FA20 and have GTX3071, Samsonas box and dry sump for it. I have also deleted the DI.
The kit you mention there retains the stock hub bearing, which is, particularly on the front, not up to much when you start pulling G on wide sticky tyres. I want to upgrade to bigger bearings and that will probably mean going the 114.3 pcd route. There are more BIG wheels available in that pattern anyhow.
Old 03-25-2016, 06:28 AM   #4
Nigelr32
Please, someone must have the answer to this issue. As I said before, there's been lots of talk about it years ago, but nothing recently?
Old 03-27-2016, 12:45 PM   #5
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Any reason why you wouldn't keep it 5x100 and use a hub adapter? I'm putting 114.3 on my car because I got an unreal deal on new wheels that had that bolt pattern.
Not trying to be an asshole,but why would you want to change the size of the stock hub if it isn't for tires with different bolt patterns? Just curious.
Th3rdSun is offline   Reply With Quote
Old 03-27-2016, 12:57 PM   #6
Cole
Not a troll
Cole's Avatar
If you actually read the post, you'd have seen he wants to use bigger bearings.
Old 03-27-2016, 06:44 PM   #7
Th3rdSun
I did read the post,but that's what I don't understand why anyone would want bigger bearings. What's the advantage?
Old 03-27-2016, 09:25 PM   #8
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
theyre stronger
andrew5826 is offline   Reply With Quote
Old 03-28-2016, 06:02 AM   #9
Nigelr32
Fact is, on track with big slicks and aero, the stock front set up is wearing quickly, giving pad knock back at best, and potential destruction of the disc and caliper.
I know there are people who will say this is BS, but if this is the case, why are so many Subaru owners uprating, why does the fastest track '86 in the world have uprated bearings and why are there uprights out there for bigger bearings to fit these cars?
Old 03-28-2016, 07:54 AM   #10
Th3rdSun
Ah,I see. Thanks for the knowledge.
Old 04-10-2016, 06:01 AM   #11
Nigelr32
So, I finally got sorted.. I have Sti 08+ rear bearings which are a bolt on fit, as long as you can drill the rear disc out.
I have also bought Sti 08+ front hubs and am now considering the options for front uprights. Brypar make billet Aluminium hubs for the FRS/BRZ/86 platform which accept the Sti bearing. I may make my own, either billet or fabricated?
And here's why I will not use conversion spacers or any bolt on spacer for that matter.. especially with sticky rubber on track
I found the pic somewhere on the net..
Old 04-10-2016, 09:52 PM   #12
xwd
I haven't really heard of folks having too many problems with the bearings. Seems like a lot of work for maybe not a lot of gain?
Those Brypar uprights are sweet and have 25mm of correction, but man $2600.
Old 04-12-2016, 06:34 PM   #13
Nigelr32
On road cars they aren't an issue but when you put big sticky rubber on them with aero and around 450 - 500hp they soon develop play. I don't want to have to redesign my front end once built, so i'm doing it now.
If you look over on the NASOIC site, there are claims of the 5 x 100 hubs wearing out quicker than the 5 x 114 by a ratio of 20:1!!
Old 04-12-2016, 07:19 PM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
You're right. 5x100 bearing is weaker than 5x114.3 bearing... but tbh, having Subie's 5x114.3 doesn't mean it's better, say if you're comparing with Toyota or Nissan 5x114.3 bearings.
If you're worry bout it then, don't go straight swap weak Subie hub bearing, but look into actual racing hub bearing that can handle it.
Just my 2 yen
Hardrace 5x114.3 Hubs JP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 80 12-11-2014 07:33 AM
USB Hubs / Splitters wahsaihin Electronics | Audio | NAV | Infotainment 2 06-14-2014 01:02 PM
Steering Wheels and Hubs Juurian Cosmetic Modification (Interior/Exterior/Lighting) 3 03-08-2013 09:21 PM
Any news on 5x114.3 front hubs for BRZ/FRS yet? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 10-25-2012 10:10 AM
