Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Better to have stickier tires up front or in rear?
I recently bought two GT radial 255/35s cheap because i needed two rears. well I would like to ditch the stretched front tires and get another set of 255/35's.
I've been looking into grippy tires such as the hankook RS-3, Star specs, R888, Etc Would it benefit me mounting those on the front or the back? I figure more grip up front would be nice, but would it benefit me more in the back? I plan to run the Gt radials until they are worn.
797Performance.com
Drives: 2019 Mazda Miata RF
Do you want oversteer, or understeer?
Not Bаnned Anymore
Drives: Heavily Modified FRS
#4 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
Country Boy 4 Life
I tried different front and rear. It caused the TCS to activate. Very very annoying!
Drives: FRS
both front and rear.
Ned flanders
I am currently running staggered tires and different brands. No issues.
797Performance.com
Ned flanders
Blah.. unfortunately A set of four isn't really in the budget right now as I still need to hit the dyno, and do some other things.
797Performance.com
#9 | |
Country Boy 4 Life
225/45 Michelin Pilot Sport A/S+ front 245/40 Nitto Motivo rear. Dangerous! Could not even go the speed limit. For comparison, 500 UTQG front 560 UTQG rear. Last edited by Leonardo; 03-22-2016 at 04:00 PM. |
#10 | |
Ned flanders
What is UTQG? I am running hankook Ventus noble 12? 225/40 front, and The GT radial 255/35 Rear. No issues. Have no TPMS installed if that could help.
797Performance.com
#11 |
Country Boy 4 Life
UTQG = Uniform tire quality grading. Or basically tire softness/hardness. The lower the number, the softer (stickier) the tire and shorter the life. Your tires are probably close enough in spec to not cause a problem. I don't think it will be the same for the RS3 and gt. Good luck.
Unless your tire pressure is out of wack, tpms will not matter. |
#12 | |
Ned flanders
797Performance.com
#13 |
Drives: Full race 4cyl boxer
Better tires in the rear - always.
In 95% of normal driving situations, it is slightly better to have the better handling tires in the front. but for the 5% of the time that it can KILL YOU, you need better grip in the rear. Unless you LIKE to have your rear end come around in panic braking situations.... |
#14 | |
Drives: 2013 Firestorm FRS
Better tires up front won't cause the rear end to come around unless you are turning, and most panic braking is in a straight line. Even with "good tires", you can still throttle-lift oversteer the car though. |
| FS: Raybestos ST-43 front and rear pads. Front for Stoptech BBK, rear for stock | rever5e | Brakes, Suspension, Chassis | 1 | 03-16-2015 12:02 PM |
| Does anyone regret putting stickier tires on? | unsurety | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 05-14-2014 03:50 PM |
| SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear | Amalgamo | Brakes, Suspension, Chassis | 3 | 04-24-2014 07:22 AM |
| Full Report: Road & Track tests stickier FR-S/BRZ tires | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 74 | 08-15-2013 01:10 AM |
| Rear Parking Brake Guard Rub (Meaty Rear Tires) | console_cowboy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-13-2013 02:39 PM |
