Old 03-22-2016, 11:52 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Better to have stickier tires up front or in rear?
I recently bought two GT radial 255/35s cheap because i needed two rears. well I would like to ditch the stretched front tires and get another set of 255/35's.
I've been looking into grippy tires such as the hankook RS-3, Star specs, R888, Etc
Would it benefit me mounting those on the front or the back? I figure more grip up front would be nice, but would it benefit me more in the back? I plan to run the Gt radials until they are worn.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-22-2016, 11:59 AM   #2
Gunman
Drives: 2019 Mazda Miata RF
Do you want oversteer, or understeer?
The Following 2 Users Say Thank You to Gunman For This Useful Post:
go_a_way1 (03-22-2016), Mr.ac (03-23-2016)
Old 03-22-2016, 12:00 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
^ this!
MisterSheep (03-22-2016)
Old 03-22-2016, 12:21 PM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
my advise would be to try to sell those GT radials and get a full set of tires.
Instagram: trevor.parque
The Following 3 Users Say Thank You to MisterSheep For This Useful Post:
continuecrushing (03-22-2016), Keenercarguy (03-22-2016), Pat (03-25-2016)
Old 03-22-2016, 12:22 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I tried different front and rear. It caused the TCS to activate. Very very annoying!
Old 03-22-2016, 12:27 PM   #6
8R6
8R6's Avatar
Drives: FRS
both front and rear.
8R6 is offline   Reply With Quote
Old 03-22-2016, 01:05 PM   #7
nickmerronesucks
Ned flanders
I am currently running staggered tires and different brands. No issues.
797Performance.com
Old 03-22-2016, 01:06 PM   #8
nickmerronesucks
Ned flanders
Blah.. unfortunately A set of four isn't really in the budget right now as I still need to hit the dyno, and do some other things.
797Performance.com
Old 03-22-2016, 03:26 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Interesting. Matching UTQG?
225/45 Michelin Pilot Sport A/S+ front 245/40 Nitto Motivo rear. Dangerous! Could not even go the speed limit.
For comparison, 500 UTQG front 560 UTQG rear.
stevemp5 (03-22-2016)
Old 03-22-2016, 04:05 PM   #10
nickmerronesucks
Ned flanders
What is UTQG?
I am running hankook Ventus noble 12? 225/40 front, and The GT radial 255/35 Rear.
No issues. Have no TPMS installed if that could help.
797Performance.com
Old 03-22-2016, 04:18 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
UTQG = Uniform tire quality grading. Or basically tire softness/hardness. The lower the number, the softer (stickier) the tire and shorter the life. Your tires are probably close enough in spec to not cause a problem. I don't think it will be the same for the RS3 and gt. Good luck.
Unless your tire pressure is out of wack, tpms will not matter.
Old 03-22-2016, 04:22 PM   #12
nickmerronesucks
Ned flanders
Oh Okay i understand now. So The sticky ones may cause an issue?
797Performance.com
Old 03-22-2016, 04:35 PM   #13
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Better tires in the rear - always.
In 95% of normal driving situations, it is slightly better to have the better handling tires in the front.
but for the 5% of the time that it can KILL YOU, you need better grip in the rear.
Unless you LIKE to have your rear end come around in panic braking situations....
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
totopo (03-22-2016)
Old 03-22-2016, 04:48 PM   #14
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
while I basically agree with this(putting better tires in rear), its typically because 95% of the population throttle-lifts mid corner, causing the rear end to come around. And 95% of the population doesn't know what to do when that happens, and so 95% of them crash/spin out.
Better tires up front won't cause the rear end to come around unless you are turning, and most panic braking is in a straight line.
Even with "good tires", you can still throttle-lift oversteer the car though.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Cole (03-22-2016), justatroll (03-22-2016)
FS: Raybestos ST-43 front and rear pads. Front for Stoptech BBK, rear for stock rever5e Brakes, Suspension, Chassis 1 03-16-2015 12:02 PM
Does anyone regret putting stickier tires on? unsurety Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-14-2014 03:50 PM
SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear Amalgamo Brakes, Suspension, Chassis 3 04-24-2014 07:22 AM
Full Report: Road & Track tests stickier FR-S/BRZ tires poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 74 08-15-2013 01:10 AM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
