Old 03-21-2016, 02:44 PM   #1
JetSpeed
Drives: 06' Forester, 15 '3.6 OBW, 16' BRZ
Cheat Codes . . .
I have heard that the dealer can re-program the BRZ so that the A/C (read a/c compressor) DOES NOT come on automatically when you turn on the air conditioning system.
Can anyone confirm that this possible and does anyone have the instructions on how to DIY??
Thank You
JetSpeed is offline   Reply With Quote
Old 03-21-2016, 02:46 PM   #2
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Thank You
Excuse my ignorance, but why is this a useful feature? Or did you mean to say 'defroster setting' instead of the bolded?
Grimlock is offline   Reply With Quote
The Following User Says Thank You to Grimlock For This Useful Post:
go_a_way1 (03-21-2016)
Old 03-21-2016, 02:47 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Up, down, up, left, square, square, R2, L2 is the cheat code for unlimited gas
Down, down, left, left, circle, square, R1, R2 is the cheat code for 221WHP
Circle, circle, X, Square R2, L2, square, square is the cheat code for all parts unlocked
The Following 23 Users Say Thank You to go_a_way1 For This Useful Post:
86kahl (03-21-2016), Aozora.BRZ (03-21-2016), Crashdummy (03-22-2016), cwpbrz-ji (03-22-2016), DavidBob (03-22-2016), Djratrap (03-21-2016), Drakiv (04-08-2016), finch1750 (04-08-2016), GT86_PRAGUE (04-08-2016), HunterGreene (03-21-2016), Husker BRZ (03-21-2016), Jfheisenberg (03-21-2016), KevinK121 (03-22-2016), MasonL1997 (03-22-2016), meWant (03-21-2016), mixtape (03-21-2016), p1l0t (03-22-2016), ScoobsMcGee (03-21-2016), shifter907 (03-24-2016), softgrip (03-22-2016), Tectoniic (03-21-2016), Toyarzee (03-21-2016), Vmax911 (03-21-2016)
Old 03-21-2016, 02:47 PM   #4
BD7
Drives: GT86
↑↑↓↓←←→→BABA
BD7 is offline   Reply With Quote
The Following 4 Users Say Thank You to BD7 For This Useful Post:
go_a_way1 (03-21-2016), p1l0t (03-22-2016), rookie (03-21-2016), trd87t (04-08-2016)
Old 03-21-2016, 02:50 PM   #5
JetSpeed
I do not like the A/C coming-on automatically when I want heat, cold, etc. everytime I start the car. Sometimes I just want the fan NOT the A/C compressor turning on/off; wears it out in the long-in also. And "no," I did not mean de-froster.
Old 03-21-2016, 02:52 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
should have got an FRS. I got a button to control my AC.
Score 1 FRS score 0 BRZ
The Following 7 Users Say Thank You to go_a_way1 For This Useful Post:
86kahl (03-21-2016), finch1750 (04-08-2016), GT86_PRAGUE (04-08-2016), MalcolmHimself (03-21-2016), STV3 (03-21-2016), Toyarzee (03-21-2016), Ultramaroon (03-21-2016)
Old 03-21-2016, 02:59 PM   #7
acetothermus
Drives: Flying in a Blue Dream
Dual zone climate control trumps that. Sorry...
And honestly, how hard is it to just flick the switch to turn the AC off? I do it automatically when I don't want the AC running.
acetothermus is offline   Reply With Quote
The Following 2 Users Say Thank You to acetothermus For This Useful Post:
go_a_way1 (03-21-2016), Tcoat (03-21-2016)
Old 03-21-2016, 03:02 PM   #8
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
The BRZ Limited HVAC system has a toggle switch which allows you to control whether the compressor is on or off. Of course, when you hit the "Auto" button, the car will revert to using the A/C compressor as it helps it do its job more efficiently. The owners' manual explains this pretty well, if I recall.
theadmiral976 is offline   Reply With Quote
The Following 3 Users Say Thank You to theadmiral976 For This Useful Post:
BRZ_Prague (03-21-2016), kch (03-21-2016), NyC Zn6 (03-21-2016)
Old 03-21-2016, 03:03 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
whats the point of dual zone in such a small car haha!! Just my opinion, I dont really want to start a debate about it But your right, its not hard to flick a switch
Old 03-21-2016, 03:05 PM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thank You
There is an option in Techstream I believe, however most dealers will probably scoff at you if you ask for it to be disabled. Any wear would be miniscule if that. You could try getting a techstream cable for $20 then pirating techstream as per the forum guide on here and attempt it even though it is a BR-Z, the only option I remember when I had techstream was definitely Defroster starting the a/c compressor but this is on an FR-S with manual a/c
Old 03-21-2016, 03:17 PM   #11
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
Originally Posted by BD7 View Post
↑↑↓↓←←→→BABA
Not to be confused with ↑↑↓↓←→←→BA
rookie is offline   Reply With Quote
The Following 2 Users Say Thank You to rookie For This Useful Post:
SubaruLifer (03-21-2016), trd87t (04-08-2016)
Old 03-21-2016, 03:46 PM   #12
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'm annoyed at this also, such a weird thing to do. However I think it's because it starts off in Auto mode everytime and if your last temp settings are lower than what it's reading, it'll automatically turn on AC.
tracerit is offline   Reply With Quote
Old 03-21-2016, 03:53 PM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Yea i have never had that problem with my dual climate. Take it off of auto mode OP.
Old 03-21-2016, 03:56 PM   #14
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
This thread...
There's an A/C button. If you don't want it running, push it until the light goes out.
Luftwaffel is offline   Reply With Quote
The Following 6 Users Say Thank You to Luftwaffel For This Useful Post:
go_a_way1 (03-21-2016), GT86_PRAGUE (04-08-2016), hypebrz (03-23-2016), Jfheisenberg (03-21-2016), NyC Zn6 (03-21-2016), PandaSPUR (03-23-2016)
DTC Codes pleong Software Tuning 12 06-11-2016 01:17 AM
Help - Two Codes Thrown jpit Engine, Exhaust, Transmission 3 04-20-2013 12:52 AM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
What do these accessory codes mean? FastLap Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 05:56 PM
