Old 03-20-2016, 02:39 AM   #1
humfrz
Small trunk lock hint here …….
I’ve had my 2013, FR-S for about 3 years and never used the key to unlock the trunk.
However, today, at the end of a grocery run, my fob wouldn’t open the trunk, neither would the inside trigger. So, I figured the valet trunk button had been punched.
Remembering there was a lock under that lip on the trunk, I tried to insert the key, it wouldn’t go. I tried it both ways (a throwback to the old days) still no go. Finally, I got it to go part way in and it didn’t want to go any further in or come out.
Finally got it out and squirted some WD-40 up in the lock and a bit on the key and it finally the key would easily go in and out and open the trunk.
If I had been out in a dark, wet parking lot, without access to a spray can of lubricant, the key might have jammed in the lock and/or I might have twisted it off trying to get into the trunk.
So, my suggestion is to give the trunk key lock a shot of lubricant.
Now, wasn’t THAT exciting! .........
humfrz
The Following 8 Users Say Thank You to humfrz For This Useful Post:
Bach415 (03-20-2016), BigFatFlip (03-20-2016), Cole (05-29-2016), Drakiv (06-01-2016), driftking96 (05-18-2016), JoeC (03-20-2016), soulreapersteve (03-20-2016), Ultramaroon (05-05-2016)
Old 03-20-2016, 03:42 AM   #2
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Yup, same thing happened to me. Funny enough, it did happen to me while camping, in the middle of no where, in the dark lol. Luckily I had a tiny can of ballistol in my glove compartment which worked just as well. I'm pretty sure I've used this trunk access 2-3 times since I bought the car lol.
Good little bit of maintenance either way.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
Bach415 (03-20-2016), humfrz (03-20-2016)
Old 05-05-2016, 04:03 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Lub fix everything~
sorry, gotta.
But thanks for reminding me....cuz i don't know how my fob won't open the trunk..... but the physical button on the trunk does.
The Following User Says Thank You to chaoskaze For This Useful Post:
soulreapersteve (05-05-2016)
Old 05-05-2016, 04:14 PM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
You needed a little bit of lubrication before you could insert it into the hole? I find that's a pretty common issue..
Instagram: trevor.parque
The Following 4 Users Say Thank You to MisterSheep For This Useful Post:
Drakiv (06-01-2016), driftking96 (05-18-2016), soulreapersteve (05-05-2016), VIP BRZ (05-05-2016)
Old 05-05-2016, 08:22 PM   #5
humfrz
Or just lick on it first ......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Cole (05-29-2016), driftking96 (05-18-2016), Ultramaroon (05-05-2016)
Old 05-05-2016, 09:24 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
humfrz
Not in the winter, tho
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
driftking96 (05-18-2016), humfrz (05-05-2016), MisterSheep (05-06-2016), Premium 615 (05-14-2016), Rifle (05-05-2016)
Old 05-29-2016, 07:44 AM   #7
WryGuy
Drives: 2014 FR-S Argento, 2003 Celica GT
This thread is only 7 posts long. But I totally derailed somewhere along the way and have utterly forgotten what the OP was all about.
WryGuy is offline   Reply With Quote
Old 05-29-2016, 05:52 PM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Dont need no lube. I go in raw and turn.
It pops right open. It is dusty though so I threw some wax in there. Maybe some W8 later...but i gotta make sure it don't drip. No one likes it when it drips.
Packofcrows is offline   Reply With Quote
10/11/13 FRS Fridays w/ a hint of BRZ donutfilling Southern California 15 10-14-2014 08:28 PM
DD with hint of autox xale Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-01-2014 07:39 AM
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 08:41 AM
11/8/13 FRS Fridays w/ a hint of BRZ donutfilling Southern California 1 11-15-2013 05:04 AM
9/13/13 FRS Fridays w/ a hint of BRZ (in SD) donutfilling Southern California 0 09-11-2013 06:33 PM
