Old 03-11-2016, 06:44 PM   #1
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
Monogram Headlights on a BRZ
Okay so I really hate the look of the BRZ headlights. I would much rather have the LED headlights from the FR-S (Monogram, 10 series, RS1) BUT as I'm sure most of y'all know, they aren't easy to come by. Also, I'm not even sure if they're a direct swap. A local guy is selling them off his FRS for $350 and that is just too cheap to pass up, plus they're right there. But is there any way to get them on to a BRZ, or are they not a direct swap? I can't find any thread on the search (all are about putting BRZ headlights on a FRS).
Also, if anyone with LED FR-S headlights wants to swap mine are brand new lol, assuming they are direct swap to the BRZ.
Edit: I also noticed the Winjet headlights are very very close. But I don't trust aftermarket as far as quality. I do a LOT of night driving, and don't need problems with visibility. Does anyone know if these (or maybe Spyders?) have better or worse light projection than OEM?
hypebrz is offline   Reply With Quote
Old 03-11-2016, 07:05 PM   #2
gtslow
Drives: 2015 Halo FR-S
I wouldn't buy the winjets as your headlights are factory HID like the Monogram/RS. I would imagine at most you would be looking at some minor repinning as that is all that it takes for a base model FR-S to hook up the BRZ headlights.
I would jump on the monogram headlights for $350 especially if they come with bulbs & ballasts. You could then sell your BRZ headlights to me for $600 and make $250 ;-)
gtslow is offline   Reply With Quote
The Following User Says Thank You to gtslow For This Useful Post:
hypebrz (03-11-2016)
Old 03-11-2016, 07:27 PM   #3
NahumCC
Drives: 2013 FR-S 10 Series
10 Series/Monogram will be straight forward for the most part. I'd have to look at your wiring diagrams but as long as Pins 5 (+) and Pin 6(-) are for the xenon bulb, Pin 7 (+) and Pin 8 (-) for the high beam shutter, and Pin 1 (+) and Pin 4 (-) for the LED DRL strip then your good.
Your problem will instead become the loss of the DOT required front turn signal/parking lamp.
Not so straight forward for you.
Your wiring on pins 5-8 are the same so you'd have the low and high beam function. However the BRZ doesn't appear to use pins 1 at all (Pin 2 is blank just like the FR-S according to the BRZ wiring diagram). Pin 3 (+) and Pin 4 (-) are your front turn signals.
Good luck.
For the TLDR
You'll be good for the Low/High beam function but thats it. You'll have no LED DRL strip except for below with the OEM BRZ DRL and you'd have no forward facing turn bulb which would give you hyper flash every time you turn on the turn signal unless you have the LED bulb relay which negates that test feature.
NahumCC is offline   Reply With Quote
The Following User Says Thank You to NahumCC For This Useful Post:
Old 03-11-2016, 08:38 PM   #4
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Good luck.
For the TLDR
Completely forgot FRS turns are integrated into the bumper. Hmmm... I suppose I will stay stock, just gonna dream that I have them anyway, thanks brotha
Old 03-11-2016, 08:40 PM   #5
NahumCC
Yeah, sorry to let the air out on that one. We each win some and lose some. After 2 years the BRZ front end has drawn me back in because I miss the look of my Viggen. At the time of purchase (aside for other factors) I wanted a slightly different front end look.
Its funny how some things just work out.
Old 03-11-2016, 08:43 PM   #6
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
I went with the BRZ because the HyperBlue, and because the limited features. I would most definitely be lying though if I said I thought the BRZ mustache and headlights looked better than the RS1 haha
Old 03-11-2016, 09:58 PM   #7
ryoma
ryoma's Avatar
how do you not like the BRZ headlights I love them and think that they're the best looking ones out of all the 86's
Old 03-11-2016, 11:18 PM   #8
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
They're alright, very "nice looking" indeed. I don't want nice lol. I want MEAN looking headlights. And every time I see my buddy taking off in his RS1 it just screams aggressive
Old 03-11-2016, 11:51 PM   #9
veck
veck's Avatar
Drives: 2014 Subaru BRZ
You could turn the frs' drl to a turn signal light.
Sent from my SAMSUNG-SM-N910A using Tapatalk
veck is offline   Reply With Quote
Old 03-11-2016, 11:53 PM   #10
ryoma
ryoma's Avatar
if you black out your headlights it gives it more of an aggressive look too
Old 03-12-2016, 12:07 AM   #11
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
Which turn bulbs are those?
MalcolmHimself is offline   Reply With Quote
Old 03-12-2016, 12:57 AM   #12
Khánh
Khánh's Avatar
Drives: sc00ter
u could turn your stock brz drl into signals.. or u can turn the monogram LEDs into Signals.. who's the guy that selling the frs headlights for 350? be careful buying because they cant be that cheap. unless they're winjet
i'll buy your brz headlights if u wanna sell though hehe
Khánh is offline   Reply With Quote
Old 03-12-2016, 02:01 AM   #13
ryoma
ryoma's Avatar
diode dynamics LED bulbs. it was whatever the middle option was, forgot what exact model they were.
Old 03-12-2016, 12:49 PM   #14
MalcolmHimself
Drives: 2015 BRZ
They look good, I like that they don't have the orange on them like a lot of other bulbs.
Monogram series headlights on a FRS DCStorm Scion FR-S / Toyota 86 GT86 General Forum 15 12-07-2020 04:59 PM
Monogram/ Series 10 Headlights fitcious Cosmetic Modification (Interior/Exterior/Lighting) 130 06-10-2016 10:07 AM
FS: Monogram Headlights - SoCal Chillz Exterior Parts (Aero, Lighting, Etc.) 10 01-25-2016 05:19 PM
For those with gt86 or monogram headlights Harmsy Cosmetic Modification (Interior/Exterior/Lighting) 2 04-08-2015 03:13 PM
WTB: FR-S Monogram Headlights willharp360 Exterior Parts (Aero, Lighting, Etc.) 0 04-21-2014 09:22 PM
