Old 05-14-2015, 02:06 PM   #1
DCStorm
DCStorm's Avatar
Drives: 2013 FR-S (RIP), 2017 Toyota 86
Monogram series headlights on a FRS
Hello everybody. I am in the process of purchasing some used frs headlights. They are the xenon monogram headlights with LED DRL strip. I just had a couple questions about these that I couldn't really find. I have seen things mentioned about adapters needed to run these? However shouldn't they be completely plug n play if they are from another FRS to put on my 2013 FRS? Will they wire right up like the 2013 OEM ones do? And do the LED DRLs light up with the low beams like the JDM ones do? Thanks in advance guys!
DCStorm is offline   Reply With Quote
Old 05-14-2015, 02:24 PM   #2
mynameisnick4
Drives: Focus RS (10 Series Prior)
The LED DRLs do not stay on with the low beams. You have to mod the harness to do that. Diode Dynamics sells a plug and play harness to enable that functionality though (which I have one coming on Saturday.)
mynameisnick4 is offline   Reply With Quote
The Following User Says Thank You to mynameisnick4 For This Useful Post:
DCStorm (05-14-2015)
Old 05-14-2015, 02:25 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
No plug and play if I am not mistaken...must be wired independently and you have to do a resistor mod in order for DRL to work with headlights. You can purchase the DRL mod through Diode Dynamics(adjustable lighting) or Beatsonic(non-adjustable lighting).
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Old 05-14-2015, 02:37 PM   #4
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I can't help with your questions; however, I will say THANK YOU! Thank you taking strides for not being one of the @$$HOLES that run HIDs in halogen headlamps blinding everyone around them. You sir, are a pure modder!
Subaru STI :
The Following 3 Users Say Thank You to Kimsey47 For This Useful Post:
@Art_Mighty (05-15-2015), sato (12-12-2020), Tcoat (05-15-2015)
Old 05-14-2015, 06:01 PM   #5
DCStorm
DCStorm's Avatar
So not plug n play even if I didn't have the LED DRL's on with the low beams? As I see I'll need an extra harness to have the DRL's on at all times.
Old 05-15-2015, 11:42 AM   #6
NyC Zn6
NyC Zn6's Avatar
In order to get the headlights to work you have to get them wired independently as the harness for the base frs is different than (6 PIN?) the Monogram/10series/rs.10 (8 PIN?). Once you get the headlight to function correctly then you can worry about the DRL mod.
Old 05-15-2015, 11:56 AM   #7
drumbum
Drives: 2016 Scion FRS Oceanic
I just did the RS1 headlamps. They are 8 Pins....
Its way easier than the writeup DIY
1.) De-Pin the RS1 headlamps
2.) De-Pin the Black plastic Housing from the "Halogen Harness"
3.) Match High beam with LEDs.... Match Low beam with HID...
4.) Use the 2 extra "plugged" "dead holes" with the remaining unused wires.
You should have 8 wires in all 8 pin holes.
I did not unplug the resistor thing as on some writeups say. The GarageFRS writeup mentioned nothing about it. Ive had the resistor plugged in for a month and all works perfect.
drumbum is offline   Reply With Quote
Old 05-15-2015, 12:24 PM   #8
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
http://www.ft86club.com/forums/showthread.php?t=24352
I've just got done doing this the hard way...
...and now someone has figured out a harness!
http://www.ft86club.com/forums/showthread.php?t=53493
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 05-15-2015, 12:30 PM   #9
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
...but most people do this wrong because the US Spec only have a wire running to the "Hi-Watt" side of the LED assembly. If you connect it as it is then the daytime LED's are actually to bright at night and are blinding to oncoming traffic I fixed this by adding back the "Low-Watt" lead. You can also look into intergrading the new Diode Dynamics always on module into your mod...
Old 07-11-2015, 08:41 PM   #10
Captae86
Drives: 86 corolla coupe
What's a good deal on a used monogram these days?
Captae86 is offline   Reply With Quote
Old 07-11-2015, 11:22 PM   #11
Shady195
Drives: '13 10 Series FRS #1203
I've seen them around 24k here in the northeast with less than 15k on them.
I've seen a few in the ~20-22k range with some paint damage on the front/rear bumpers.
Shady195 is offline   Reply With Quote
Old 07-12-2015, 07:31 AM   #12
Captae86
I've found one at 23k with low mileage, guess is a good deal
Old 07-13-2015, 06:31 AM   #13
jlugo711
Drives: 2014 GT86
He said they were ''Monogram'' headlights though, which have HID housings for the HID projectors they use. I'm confused?
OP I used the write-up on the forums to wire up my Monogram lights and everything came out great.
jlugo711 is offline   Reply With Quote
Old 07-13-2015, 03:22 PM   #14
Kimsey47
Kimsey47's Avatar
Yes, he's doing things the RIGHT way and that's why I applaud him!
Subaru STI :
Monogram/ Series 10 Headlights fitcious Cosmetic Modification (Interior/Exterior/Lighting) 130 06-10-2016 10:07 AM
Monogram/10 series Toyota headlights with adapters Calavera Exterior Parts (Aero, Lighting, Etc.) 8 05-10-2015 08:46 PM
Monogram Series Headlights. SOLD JDis3 Exterior Parts (Aero, Lighting, Etc.) 6 11-03-2014 12:16 AM
FS BNIB Series 10/ Monogram Headlights ecda Exterior Parts (Aero, Lighting, Etc.) 5 09-30-2014 06:28 AM
WTB: PLUG N PLAY Harness from the 10 Series/ Monogram Headlights LANI86 Want-To-Buy Requests 1 09-24-2014 11:50 PM
