Old 03-10-2016, 05:19 AM   #1
Gwhite69
Drives: 2013 Scion FRS
LED headlights?
Looking to put in LED high and low beams. I need suggestions for brand I should go with. Thanks in advance.
Gwhite69 is offline   Reply With Quote
Old 03-10-2016, 08:28 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I wouldn't do it for high beams I hear the Led light output doesn't go as far down the road. Order from ft86speed factory if they still sell the ones they got. They have grea service if anything goes wrong with them
Old 03-10-2016, 09:43 AM   #3
Diode Dynamics
Diode Dynamics's Avatar
Check out this thread for more information on LED low-beams: http://www.ft86club.com/forums/showthread.php?t=81340
Thanks!
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
go_a_way1 (03-10-2016)
Old 03-10-2016, 11:08 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Thanks!
Nick C.
^ oh yeah forgot about these guys!! They are your LED go to guys FYI
Diode Dynamics (03-10-2016)
Old 03-10-2016, 07:40 PM   #5
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Thanks!
Nick C.
I saw in one of the reviews of the multi colored LED DRL's that you lose your ability to have high beams. Is that true for LED DRL's?
Also, the bulb design of the colored LED isnt listed in the description of how bright it is compared to stock like the rest are. Just curious
Autocon is offline   Reply With Quote
Old 03-10-2016, 08:05 PM   #6
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Can Confirm. If you care about your high beams do NOT switch your DRL's to LED's. Ended up switching my DRL's back to stock bulbs because the output of my low beams were better than my LED*hi-beam.
itsibarra is offline   Reply With Quote
The Following User Says Thank You to itsibarra For This Useful Post:
Autocon (03-10-2016)
Old 03-11-2016, 01:50 AM   #7
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Just get a bixenon projector swap. That way, you can keep your LED DRL's and have high beam.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Ultramaroon (07-23-2016)
Old 03-11-2016, 08:59 AM   #8
Diode Dynamics
The RGB LED DRL's are definitely a cosmetic upgrade only. They are not going to give you a significant amount of usable output, so if you use your high-beams often, I'd stick with a single-color bulb.
Nick C.
John C.
Diode Dynamics
Autocon (03-11-2016)
Old 07-23-2016, 03:43 PM   #9
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
I'm reading up on long term reliability of HID vs LED bulbs and I'm wondering, does a constant switching on and off affect the life span of led bulbs or does that only apply to hid?? I read about the difference how much voltage is needed to strike the arc of a cold lamp vs hot lamp.
Jajanken86 is offline   Reply With Quote
Old 07-24-2016, 10:18 AM   #10
stevesnj
stevesnj's Avatar
I have these....they've been working great since November. Each bulb needs to be at least 2000 lumen each. Also you need to re aim your headlights after or they will be too high.
https://www.amazon.com/Partsam-Power..._cd_al_qh_dp_t
My 2016 Build thread
Old 07-24-2016, 10:22 AM   #11
stevesnj
stevesnj's Avatar
These are a diode light, they barely emit any heat, not effected by on off cycles, the ballast will protect it from any spikes or under volt. about 50,000 hours life. Thats 6 years of life if you keep your headlights on 24/7 for 6 years.
The Following User Says Thank You to stevesnj For This Useful Post:
Jajanken86 (07-26-2016)
WTT: Trading my blacked out OEM headlights for your stock chrome headlights DCStorm Exterior Parts (Aero, Lighting, Etc.) 7 06-28-2015 11:01 AM
NJ FT:Black BRZ headlights for Stock BRZ headlights Jive Turkey NY / NJ / CT / PA 2 05-31-2015 05:48 PM
NJ FT:Black BRZ headlights for Stock BRZ headlights Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 11 05-30-2015 09:53 AM
GT86 headlights vs. Maserati Ghibli Headlights l0aded Scion FR-S / Toyota 86 GT86 General Forum 7 08-29-2014 08:39 AM
