Drives: 2013 Scion FRS
LED headlights?
Looking to put in LED high and low beams. I need suggestions for brand I should go with. Thanks in advance.
#2 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I wouldn't do it for high beams I hear the Led light output doesn't go as far down the road. Order from ft86speed factory if they still sell the ones they got. They have grea service if anything goes wrong with them
#3 |
Check out this thread for more information on LED low-beams: http://www.ft86club.com/forums/showthread.php?t=81340
Thanks! Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | go_a_way1 (03-10-2016) |
#4 | |
Not Bаnned Anymore
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Diode Dynamics (03-10-2016) |
#5 | |
Drives: 2014 Whiteout FRS
Also, the bulb design of the colored LED isnt listed in the description of how bright it is compared to stock like the rest are. Just curious
#6 | ||
Drives: Supercharged Car
| The Following User Says Thank You to itsibarra For This Useful Post: | Autocon (03-10-2016) |
#7 |
Custom User Title
Drives: Asphalt FR-S MT
Just get a bixenon projector swap. That way, you can keep your LED DRL's and have high beam.
| The Following User Says Thank You to boredom.is.me For This Useful Post: | Ultramaroon (07-23-2016) |
#8 | |
Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | Autocon (03-11-2016) |
#9 |
Drives: Silver FR-S
I'm reading up on long term reliability of HID vs LED bulbs and I'm wondering, does a constant switching on and off affect the life span of led bulbs or does that only apply to hid?? I read about the difference how much voltage is needed to strike the arc of a cold lamp vs hot lamp.
#10 |
I have these....they've been working great since November. Each bulb needs to be at least 2000 lumen each. Also you need to re aim your headlights after or they will be too high.
https://www.amazon.com/Partsam-Power..._cd_al_qh_dp_t
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#11 | |
| The Following User Says Thank You to stevesnj For This Useful Post: | Jajanken86 (07-26-2016) |
| WTT: Trading my blacked out OEM headlights for your stock chrome headlights | DCStorm | Exterior Parts (Aero, Lighting, Etc.) | 7 | 06-28-2015 11:01 AM |
| NJ FT:Black BRZ headlights for Stock BRZ headlights | Jive Turkey | NY / NJ / CT / PA | 2 | 05-31-2015 05:48 PM |
| NJ FT:Black BRZ headlights for Stock BRZ headlights | Jive Turkey | Exterior Parts (Aero, Lighting, Etc.) | 11 | 05-30-2015 09:53 AM |
| GT86 headlights vs. Maserati Ghibli Headlights | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-29-2014 08:39 AM |
