Old 03-03-2016, 11:24 AM   #1
UNCC_BRZ
UNCC_BRZ's Avatar
Drives: 2013 WRB BRZ Limited
Securing subwoofers
Any tips on securing my subwoofer? I have read that velcro works well, but does the glue side actually work on carpet? Or do I need to get double sided hook velcro?
I dont really want to drill into anything if possible, because L-brackets would be the obvious choice there.
UNCC_BRZ is offline   Reply With Quote
Old 03-03-2016, 11:27 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Do you drive the FRS likes its meant to be driven? If you do, then you will need to drill things to hold it in place. If you drive the FRS just for show and because its a "cool" car you will probably be fine with something like Velcro
*Fun fact* its called hook and loop tape, Velcro is just the brand
The Following 3 Users Say Thank You to go_a_way1 For This Useful Post:
MaXimus (03-08-2016), stevemp5 (03-03-2016), UNCC_BRZ (03-03-2016)
Old 03-03-2016, 12:50 PM   #3
UNCC_BRZ
UNCC_BRZ's Avatar
I dont track the car at all, but i drive it pretty hard.
but my real question is, does the glue side of the velcro tape stick to the carpet?
And I did in fact know it is hook and loop tape! Velcro is the best brand =)
The Following User Says Thank You to UNCC_BRZ For This Useful Post:
go_a_way1 (03-03-2016)
Old 03-03-2016, 01:05 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
1) Okay then I would highly recommend you drill some holes and do it right. You could get a custom wood trunk liner made up
so drilling into that is 100% removable.
2) No the glue will not stick to the carpet very well at all.
3) dam straight Velcro is the best.
Old 03-03-2016, 01:09 PM   #5
UNCC_BRZ
UNCC_BRZ's Avatar
I'll look into that!
Old 03-03-2016, 01:18 PM   #6
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
Bolted down is the only acceptable way to mount a subwoofer box in a car. Think about what happens if you get in an accident, your fault or not. That box becomes a potentially lethal projectile. And yes it's happened before. Last case I remember was about 4 months ago, car pulled out in front of neon and when the neon hit the other car, the box broke through the rear seat and killed the driver.
TOOSTUBBORN2FAIL is offline   Reply With Quote
The Following User Says Thank You to TOOSTUBBORN2FAIL For This Useful Post:
Old 03-03-2016, 01:19 PM   #7
UNCC_BRZ
UNCC_BRZ's Avatar
Old 03-03-2016, 01:20 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
He is right you know
Old 03-03-2016, 01:58 PM   #9
TOOSTUBBORN2FAIL
My last build had the subwoofer and kick panels bolted through the floor pan with 1/4-20 bolts. Of course, my sub box weighed 55 pounds and my kick panels weighed 25 pounds each.
FS/FT: Subwoofers with Enclosure 86Hiro Audio/Visual, Electronics, Infotainment, NAV 0 07-06-2015 02:45 PM
Image Dynamics ID8 V.3 8" subwoofers bear89103 Audio/Visual, Electronics, Infotainment, NAV 1 07-03-2015 12:41 PM
Trying to put 2 Jl audio subwoofers in my 2014 Scion FR-S Braddwtnx Scion FR-S / Toyota 86 GT86 General Forum 0 06-25-2015 09:07 PM
Recommended powered subwoofers (is that what they're called?) oldpueblo Electronics | Audio | NAV | Infotainment 24 04-28-2015 12:17 PM
Exhaust or Subwoofers? mervingee BRZ First-Gen (2012+) — General Topics 29 08-07-2014 09:47 AM
