Drives: FR-S 2013 Asphalt
Widebody correct fitment
Sort of at an Impasse here.
Ordered Lux motion Widebody kit but cannot come to a decision for wheels. I'd like to have wide tires, as opposed to wide "wheels." I see lots of people running 10-11" wide wheels, but 265 tires. I'm looking to run 285 to 315 depending on what will fit under the widebody best and provide the best selection/value of tires. Does anyone have any ideas? The lux motion kit is +100mm front +120mm rear on clearance. Eventually I would like to go with air suspension and I'm not certain how much extra clearance of the suspension is required with that and a 1" drop. |
#2 | |
Drives: 2013 Raven FRS
There's a calculator online, that suggested with stock suspension, you could fit 13 inch wide wheels in the back without rubbing, assuming the correct offsets, and stock ride height. I know it's not enough, but it's a place to start I suppose?
I used Rimsntires.com calculator. I got these figures, for wheels. I don't know how much further you could go towards the suspension before rubbing air suspension components. Maybe someone with Airrex or Air Lift could chime in?
100 tire choices (215/45R17 +0% 97mm sidewall *Stock* 21 tire choices (285/30R18) +0.5% 86mm sidewall 19 tire choices (295/30R18) +1.5% 89mm sidewall 3 tire choices (315/25R19) +2.3% 79mm sidewall 12 tire choices (335/30R18) +5.3% 101mm sidewall 21 tire choices (305/30R19) +6.5% 92mm sidewall |
Drives: 2005 Toyota Camry
You need to start with basic information first... such as what alignment, ride height, etc the car will be at.
Then figure out what width the body is going to be at over stock, and then lastly look at current fitment of wheels on stock body for context. It's hard to provide advice on tire/wheel sizing when you can run anywhere from zero to -3 camber and have a huge difference in fitment. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | AtlasMick (01-20-2014) |
| Offset and fitment on Varis Widebody | davidshu0327 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 03-31-2020 10:20 PM |
| Which EL Header Correct Torque Dip Best? | slava | Engine, Exhaust, Transmission | 56 | 02-20-2019 07:50 AM |
| Correct oil filter for 86? 130 or 160/15A? | kharn83 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 11-27-2013 01:28 AM |
| Do these look correct for our car? 9005 Replacement | BlackyRose | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-24-2013 11:15 AM |
| correct idle rpm after warmup | StormTrooper | Issues | Warranty | Recalls / TSB | 11 | 04-27-2013 07:00 PM |
