Old 03-01-2016, 11:56 PM   #1
manualmotive
manualmotive's Avatar
Drives: '14 BRZ Todoroki/OriginLabo
just another ruined BRZ
This is just a little thread to keep track of some of the shit I've done to my car and share some photos.
I used to hate slammed cars and now the frame of mine is an inch off the ground But its still fun as hell to drive and that's all that matters to me.
I'm @ seankfoto on instagram if any of yall are on there.
Current setup:
Suspension/Wheels
- Stance SS coilovers 12k(5" swift)/8k
- Powered By Max rear LCA
- Megan rear toe arms
- Powered By Max solid subframe & differential risers
- front camber bolts 16mm top, 14mm bottom
- ARP extended studs all around
- ESR SR05 18x9.5 +35 (+10f, +15r after spacers) on accelera 215/35
Engine/Exhaust
- Berk 2.5" high-flow catted frontpipe
- custom 2.5" resonated catback with 2x2.5" blastpipes (by Big B Mufflers)
Exterior/Interior
- CS style front lip, sideskirts & rear spats
- TRD style fender bezels
- Valenti CR taillights
Old setups/full build history:
2014 Subaru BRZ Premium in Satin White Pearl, purchased on 2.18.14
1680 miles
- Eibach Sportline springs
2600 miles
- Whiteline 16mm front camber bolts (for upper slot)
- XXR 527 17X8.25 +35 flat black
- Hankook Evo2 245/40
7350 miles
- Berk high flow catted 2.5" frontpipe
- custom 2.5" catback (Big B Mufflers)
8550 miles
17300 miles
- Stance coilovers 8k/6k
- Vordoven Forme9 17x9 +35 painted gold
- Federal 595 245/40
- STi style front lip
- Grimmspeed license plate relocator
- chrome fender garnish delete
21,500 miles
- Powered By Max rear lower control arms
- Swift 12k springs (5") for front; moved 8k to rear
25,000 miles
- Ikon lip for about a week
- CS style front lip, sideskirts & spats
- SPC 14mm front camber bolts (for bottom slot)
- ESR SR05 18x9.5 +35 on Accelera 215/35
- 25mm spacer front, 20mm spacer rear; camber -5f -4.5r
- 2.5" catback with 2x2.5 'blast pipes'
27,000 miles
- replaced broken axle
- Powered By Max solid differential & subframe risers
in progress ~28,000 miles
- 20K 4" Swift spring for front, moved 5" 12K Swift to rear
- replace differential
- (2) ESR SR05 18x9.5 +22 for front (same wheel lower offset) = -3 after spacers
- the subframe/diff raise pushed out the rear wheels about 12mm per side, so a smaller spacer can be ran (20mm -> 10)
- quik-latch front bumper quick releases
- alignment: camber -5f, -2.5r; toe +0
manualmotive is offline   Reply With Quote
Old 03-02-2016, 12:09 AM   #2
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Old 03-02-2016, 12:16 AM   #3
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by manualmotive View Post
Need to take better photos but I recently lost my differential's drain plug from bottoming out on so much shit, so I'm waiting for the dealership to receive a new plug before I can drive again. Which is why I was bored enough to compile a thread for my ruined little ricerocket.
Old 03-02-2016, 12:23 AM   #4
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Build Thread
Instagram
Old 03-02-2016, 03:28 AM   #5
akidnamedguiza
akidnamedguiza's Avatar
Drives: 2013 Subaru BRZ
It's awesome seeing the progress like this on a build! Keep it up!!
Sent from my SM-N900V using Tapatalk
akidnamedguiza is offline   Reply With Quote
Old 03-03-2016, 09:57 PM   #6
manualmotive
Originally Posted by ATL BRZ View Post
I've had AAA drive all the way to me just to tell me to essentially fuck off because my car was "too modified" (when it was on stock wheels) and "too low" to tow. Fucking bullshit because the next tow driver they sent (2 hours later) had no problem getting it on.
Originally Posted by midnight23 View Post
Workin on it right now haha!
Originally Posted by Juvenile View Post
Thanks!
I'm enjoying the majority of replies being memes. Keep it up lol
Old 03-03-2016, 10:12 PM   #7
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
I like seeing different things with these motors, better that than seeing the same track builds being recycled over and over.
secret.squirrel is offline   Reply With Quote
Old 03-04-2016, 09:28 AM   #8
ATL BRZ
ATL BRZ's Avatar
The fact that you're still dedicated to scraping and understeering your car all over the place is a testament to just how far some owners will go to have their car look broken while hardparked.
Old 03-04-2016, 09:30 AM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Herrafrush....with spacers....lol.
Old 03-04-2016, 09:46 AM   #10
Cole
Not a troll
Cole's Avatar
And rep wheelz
Whatever though. Looks good enough for an absolutely non-functional vehicle
Old 03-04-2016, 10:37 AM   #11
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
The equivalent of stanced cars, for parachuting, is a parachute with holes in it.
fumanchu1 is offline   Reply With Quote
Old 03-04-2016, 11:17 AM   #12
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
MY 86 BUILD
[YOYO] is offline   Reply With Quote
Old 03-04-2016, 11:19 AM   #13
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
I like the way it looks. Some guys track, some guys scrape. Do whatever you'd like. Did you need absolutely need the rear toe arms to correct the geometry at that camber level? I've read about some guys running -4 in the back on OEM arms
eggncheese is offline   Reply With Quote
Old 03-04-2016, 11:40 AM   #14
manualmotive
Y'all are great. Unfortunately the car is far from being "absolutely non-functional" as its still my daily driver, still pulls away from "functional" cars in the canyon (but that is more dependent on the driver), and is still fun as hell to slide (probably more than ever). I don't do it for "hardparking", I drive it 90% as hard as I ever have. The thing about slamming a car that is built for handling is that it still drives pretty damn good even with a completely retarded suspension geometry. Understeering is annoying but it's only certain turns and even then it's still better than a stock WRX. If you're going to hate on low cars at least bring some interesting arguments. TBH I'm tempted to go lower all around with stiffer springs but then it would actually be fucking impossible to drive. My fuel tank is already dented enough lol.
Agreed on the spacers and rep wheels though hahaha it's a work in progress. Trying to save for a trip to Japan now instead of blowing it all on dumb car shit.
Exactly... it still works
63,000 and throwout bearing ruined everything riironman Issues | Warranty | Recalls / TSB 188 05-14-2016 11:02 AM
Think I ruined the paint :( Muskokan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 28 10-13-2013 01:11 PM
Friday Ruined... mbh1101 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 07-20-2013 01:58 PM
Scion FR-S completely ruined during a high-speed chase vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 2 07-05-2013 12:09 PM
How do you know that your day is already ruined? IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 4 12-03-2012 09:58 AM
