Old 06-29-2012, 05:47 PM   #1
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Removing and Replacing your BRZ/FR-S Accessory Belt
GrimmSpeed DIY Guide Series
Updated 6/29/12
Introduction: This guide will illustrate how to inspect and change the accessory belt on your BRZ/FR-S.
Tools: The tools listed below are suggested for this task (figure 1). Optional tools are noted.
- Needlenose Pliers
- ¼ in Ratchet
- ¼ in Extension
- ¼ in drive deepwell 10mm socket
- 3/8 in Ratchet
- 3/8 in 12mm socket
- Screwdriver
Tips:
Procedure:
1. Begin by following our intake removal guide to expose the belt.
2.
Next, remove the black covers on the alternator and power steering pump.
3.
Use your 3/8in drive 12mm socket and wrench on the tensioner pulley as shown below. This will release tension on the belt and you should be able to slip it off of the idler pulley with no issues. After the belt is removed, you can slowly bring the tensioner back.
4. Easy as that. Re installation is just the reverse. Remember to double check that the belt is properly routed and seated in each pulley before starting the car.
GrimmSpeed is offline   Reply With Quote
The Following 11 Users Say Thank You to GrimmSpeed For This Useful Post:
ATL BRZ (07-06-2012), baldolera (08-17-2012), civicdrivr (06-30-2012), cmspooner (07-27-2012), ddevl_86 (03-25-2021), FRSPirate (06-29-2012), kwood9000 (07-23-2012), neutron256 (07-23-2012), Sportsguy83 (06-30-2012), Style (08-02-2012), ts87 (12-15-2013)
Old 06-29-2012, 06:26 PM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 07-23-2012, 08:53 PM   #3
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
FYI to anyone trying to attempt this, pulley is pushed down as if you are trying to tighten the pulley to remove the tension not the way shown on the picture.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
The Following User Says Thank You to FRSPirate For This Useful Post:
ATL BRZ (07-23-2012)
Old 07-23-2012, 10:18 PM   #4
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
To clarify, you're saying the tensioner pulley is loosened with a clockwise (righty tighty) effort with a socket wrench? Weird but thanks for the tip.
Old 07-23-2012, 10:27 PM   #5
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
It's not weird; the reverse thread prevents it from loosening on its own.
Subie is offline   Reply With Quote
Old 07-23-2012, 11:51 PM   #6
FRSPirate
FRSPirate's Avatar
You do not actually loosen the pulley, it pivots out of the way and the pivot point is where the bracket mounts to the engine (don't let go once you release the tension, the bracket is spring loaded.) Basically put a wrench on the pulley bolt like in the picture above, have the wrench orientated just like in the picture and push down towards the bottom of the car. It should be obvious once you start to apply pressure. It does not require much force but be careful because again it is spring loaded so it could snap back and fling the wrench in your face.
EDIT: Pictures have been fixed thanks to Matt from GrimmSpeed. Info above is correct!
-Alex
05 Raven R6
13 Raven FRS M/T
The Following 2 Users Say Thank You to FRSPirate For This Useful Post:
ATL BRZ (07-24-2012), Bonburner (07-24-2012)
Old 07-24-2012, 10:02 AM   #7
GrimmSpeed
GrimmSpeed's Avatar
Thanks for catching that! I've updated the image to show the correct direction.
Yep.
:happy0180:
Matt
The Following User Says Thank You to GrimmSpeed For This Useful Post:
FRSPirate (07-24-2012)
Old 07-27-2012, 02:59 PM   #8
mike2100
mike2100's Avatar
Drives: 23 BRZ
You don't even need to remove the covers for the alternator and a/c compressor pullies.
mike2100 is offline   Reply With Quote
Old 12-30-2012, 05:25 PM   #9
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I may have inadvertently over-tightened the v-belt tensioner when releasing belt pressure. Does anyone have the proper torque value for the tensioner pulley bolt?
Also, to be clear, this is reverse-threaded, correct?
Thanks!
cobrabyte is offline   Reply With Quote
Old 01-02-2015, 03:00 AM   #10
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I was just reading thru this and I think you made a mistake .. I believe the other black cover is for the a/c compressor ..Please correct me if I'm wrong
Thanks
Young_makaveli is offline   Reply With Quote
Old 06-06-2015, 11:39 PM   #11
Germanjap
Drives: 2013 JRSC Firestorm FR-S
Just did it. It's a 14 mm wrench and socket for the tensioner not a 12 mm.
Germanjap is offline   Reply With Quote
The Following User Says Thank You to Germanjap For This Useful Post:
Turdinator (11-15-2016)
Old 04-24-2019, 08:20 PM   #12
ASdispatch
Drives: GBM Subaru BRZ
Any chance anyone knows the part number of the tensioner
pulley bolt? I've tried googling it but all I can find is the idler pulley bolt. I sheared mine off.
ASdispatch is offline   Reply With Quote
Old 04-25-2019, 04:53 PM   #13
sandraw_86
sandraw_86's Avatar
Drives: 2015 FR-S
I would recommend reaching out to Toyota/Subaru dealership, they should know the part number...
sandraw_86 is offline   Reply With Quote
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Seat belt issues skoodge Scion FR-S / Toyota 86 GT86 General Forum 55 08-04-2014 03:41 PM
STi's newest accessory!!! Godzpeed Off-Topic Lounge [WARNING: NO POLITICS] 7 07-08-2012 01:21 AM
Red Seat Belt - where to get? MarkMash Cosmetic Modification (Interior/Exterior/Lighting) 11 06-24-2012 11:55 AM
You wish you were this seat-belt! YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 05-03-2012 07:43 PM
