Drives: Late 2014 Subaru BRZ
Vacuum lines - Hard or SS braided.
I'm intrested, is anyone running a custom hard vacuum lines for the BOV, WG and so on? Or even a custom SS braided?
I see this is a practice with or higher end cars that don't want to deal with heat cracking the lines and causing boost or vacuum leaks. I'm thinking of giving myself a fun project that doesn't break the bank.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
[insert cool phrase here]
Drives: BRZ Premium
It's just a silly jacket over normal vacuum lines.
You can buy just the jacket and bling it up. Or spend a few and buy one already on. It's up to you. But really it offers little protection. Just makes it look cool.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: Sterling BRZ Ltd
Scroll through my build thread, I use braided lines for my wastegate and hard lines for my turbo coolant and crank case vent. My wastegate line runs past the manifold so I also heat sleeve it.
Drives: 2JZ FRS
All mine are push loc. Been fine for over a year and 30psi
#5 | |
Drives: blue - Cosworth SC stage 3.0
sorry but that's not correct proper aerospace / aeroquip braided hose is proof to at least 100bar internal pressure ( for the small bore any way) and the braid protects the inner hose from any chance of fretting through due to general mishandling or impact there's a reason its de rigeur choice on aircraft and racing cars... |
mrk1, that's exactly what i'm talking about! Looks great. I think i'll make myself a little project. Where did you get all your fittings JEGS?
2014 Subaru BRZ
#7 | |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Yea I think I will be going to SS braided lines with my new motor, then again I see tons of other high hp cars not running SS lines
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
It's really case by case. On my car the wastegate lines runs between the crank pulley and manifold so I wanted something I can rely on. The blow off line is up and out of the way so that's a normal silicon line.
| Stoptech Braided Lines | CatDaddysBBQ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-25-2015 09:20 PM |
| DIY/Review: Dezod SS Braided Brake Lines | TheBatman | DIY (Do-It-Yourself) Guides | 2 | 10-14-2013 12:48 PM |
| ~D3PE Stainless Braided Clutch Lines!~ | Evan@D3PE | Transmission and Driveline | 23 | 04-30-2013 09:50 AM |
| [SYD] HEL Stainless Steel Braided lines (F&R) BRAND NEW | eckoflyte | Australia Classifieds | 5 | 02-05-2013 08:33 PM |
| New! Mach V stainless braided brake lines | Mach V Dan | Brakes, Suspension, Chassis | 5 | 10-10-2012 12:32 PM |
