Old 02-26-2016, 11:03 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Vacuum lines - Hard or SS braided.
I'm intrested, is anyone running a custom hard vacuum lines for the BOV, WG and so on? Or even a custom SS braided?
I see this is a practice with or higher end cars that don't want to deal with heat cracking the lines and causing boost or vacuum leaks.
I'm thinking of giving myself a fun project that doesn't break the bank.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-27-2016, 12:20 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's just a silly jacket over normal vacuum lines.
You can buy just the jacket and bling it up. Or spend a few and buy one already on.
It's up to you.
But really it offers little protection. Just makes it look cool.
Old 02-27-2016, 08:39 AM   #3
mrk1
Drives: Sterling BRZ Ltd
Scroll through my build thread, I use braided lines for my wastegate and hard lines for my turbo coolant and crank case vent. My wastegate line runs past the manifold so I also heat sleeve it.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Dream20b (02-27-2016)
Old 02-27-2016, 01:06 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
All mine are push loc. Been fine for over a year and 30psi
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
nickmerronesucks (03-02-2016)
Old 02-27-2016, 01:29 PM   #5
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
It's up to you.
sorry but that's not correct
proper aerospace / aeroquip braided hose is proof to at least 100bar internal pressure ( for the small bore any way) and the braid protects the inner hose from any chance of fretting through due to general mishandling or impact
there's a reason its de rigeur choice on aircraft and racing cars...
Matt@Cosworth is offline   Reply With Quote
Old 02-27-2016, 01:45 PM   #6
GsxrMe
GsxrMe's Avatar
mrk1, that's exactly what i'm talking about! Looks great. I think i'll make myself a little project. Where did you get all your fittings JEGS?
2014 Subaru BRZ
Old 02-27-2016, 02:31 PM   #7
mrk1
http://www.verociousmotorsports.com/
The Build Thread
Old 03-02-2016, 04:13 AM   #8
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Yea I think I will be going to SS braided lines with my new motor, then again I see tons of other high hp cars not running SS lines
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 03-02-2016, 07:27 AM   #9
mrk1
It's really case by case. On my car the wastegate lines runs between the crank pulley and manifold so I wanted something I can rely on. The blow off line is up and out of the way so that's a normal silicon line.
The Build Thread
#maverick# (03-02-2016)
Stoptech Braided Lines CatDaddysBBQ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-25-2015 09:20 PM
DIY/Review: Dezod SS Braided Brake Lines TheBatman DIY (Do-It-Yourself) Guides 2 10-14-2013 12:48 PM
~D3PE Stainless Braided Clutch Lines!~ Evan@D3PE Transmission and Driveline 23 04-30-2013 09:50 AM
[SYD] HEL Stainless Steel Braided lines (F&R) BRAND NEW eckoflyte Australia Classifieds 5 02-05-2013 08:33 PM
New! Mach V stainless braided brake lines Mach V Dan Brakes, Suspension, Chassis 5 10-10-2012 12:32 PM
