Old 02-25-2016, 01:50 PM   #1
clbembry
clbembry's Avatar
Will -1 camber get rid of this tire poke?
I want the top of the tire to be flush, will -1 camber accomplish this? Thanks.
Sent from my HTC One_M8 using Tapatalk
clbembry is offline   Reply With Quote
Old 02-25-2016, 01:52 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
No, thats a lot of poke. It will tuck the top in a little but the middle of the tire will not change and the bottom will poke out more.
edit: read updated post, I would say 3-4 maybe to get where you need, but I am no expert on "hella-flush" hahaha
Old 02-25-2016, 01:52 PM   #3
8R6
8R6's Avatar
Drives: FRS
whats your wheel specs and tires? that "looks" like something similar to a 9" width with 245 tires, and on stock suspension...
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
clbembry (02-25-2016)
Old 02-25-2016, 02:02 PM   #4
clbembry
clbembry's Avatar
245 with 18x8.5 +30, anything I can do do the suspension to reduce poke? Doesn't need to be flush I just don't want to be kicking up rocks and ruining my paint/hitting people behind me.
Old 02-25-2016, 02:22 PM   #5
clbembry
clbembry's Avatar
I don't care if it pokes out at the bottom, it's mostly the top I care about for aesthetics.
Old 02-25-2016, 02:23 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Just by eyeballing it I would guess -3 is were you should start
Old 02-25-2016, 02:23 PM   #7
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
You will likely need more negative camber. Add camber, possibly lower it (if the height bothers you, aesthetically), add mud flaps.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
Old 02-25-2016, 02:31 PM   #8
clbembry
clbembry's Avatar
Isn't -3 a lot? I don't want to wear on my tires excessively. I also don't need hella flush, almost flush will do.
Old 02-25-2016, 02:33 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
lowering+camber is gonna be the best you can do
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 02-25-2016, 02:35 PM   #10
continuecrushing
-3 is on the higher side, but its doable.
Toe has more of an effect on tire wear. Just hit up the track/canyon to keep things even.
go_a_way1 (02-25-2016)
Old 02-25-2016, 02:36 PM   #11
clbembry
clbembry's Avatar
Why does lowering a car tuck the wheels in?
Old 02-25-2016, 02:36 PM   #12
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
I would say that approx -2 camber will help pull in the top as much as possible and still won't promote excessive shoulder wear. Once you pass 2 ish and don't flog the car at a track, you will start to notice the uneven wear on a McPherson type front suspension setup. I got 17x9 +35 and got neg 1.7 up front with a single set of camber bolts (with lowering springs) and it made it much better. I'm not as familiar with your wheel width and offset however...
Toyarzee is offline   Reply With Quote
The Following 2 Users Say Thank You to Toyarzee For This Useful Post:
go_a_way1 (02-25-2016), hmong337 (02-26-2016)
Old 02-25-2016, 02:37 PM   #13
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You would need to have different wheels / tires to run less camber and not poke.
The Following 3 Users Say Thank You to Summerwolf For This Useful Post:
Cole (02-26-2016), go_a_way1 (02-25-2016), wparsons (02-26-2016)
Old 02-25-2016, 02:38 PM   #14
Toyarzee
Shibby!
Toyarzee's Avatar
You're changing the suspension geometry and the control arm angle relative to vehicle as it sits lower. The lower you go, the more uncorrected neg camber you'll get
The Following User Says Thank You to Toyarzee For This Useful Post:
Immobilizer - where is it? How can i poke at it? im_topher Engine, Exhaust, Transmission 8 11-10-2015 12:29 PM
What can I do about poke? Don't know what I'm doing rinnamon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 04-05-2015 09:38 PM
Eibach Pro-Kit Camber adjustment & tire question JMOrem Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-07-2014 03:02 PM
Poke's BRZ build Pokeguyjai Member's Car Journals 5 03-15-2014 11:10 AM
Help with poke on rear Ash.B Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-23-2013 07:19 AM
