Old 02-23-2016, 04:56 PM   #1
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
Berk Frontpipe to Perrin CBE install question
Sorry if it's already been posted,
Was wondering if you are supposed to reuse the stock donut gasket between the Front Pipe and Midpipe?
Perrin uses a flat gasket, so do I just chop off the extended bit of piping on the end of the Berk Front pipe to mate the 2 ends together with a flat gasket in between?
Just wanted to clarify before I go cutting things up
Thanks!
mike7792 is offline   Reply With Quote
Old 02-23-2016, 05:24 PM   #2
kch
Senior Misanthrope
kch's Avatar
Thanks!
Toss the donut, cut off the end, and use a flat gasket with normal (non-springy) bolts.
Old 02-23-2016, 05:29 PM   #3
e1_griego
e1_griego's Avatar
Drives: Many
You shouldn't need to cut anything. Gasket should fit over the end and fit inside the perrin flange.
e1_griego is offline   Reply With Quote
Old 02-23-2016, 06:27 PM   #4
mike7792
mike7792's Avatar
So slide the donut onto the frontpipe end and fit that end with donut into the perrin midpipe without a gasket?
Old 02-23-2016, 06:30 PM   #5
e1_griego
e1_griego's Avatar
Drives: Many
No donut. just the flat gasket.
Old 02-23-2016, 06:52 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The flat gasket is for the overpipe to front pipe.
The stock donut gasket is reused.
-alex
Old 02-23-2016, 07:04 PM   #7
e1_griego
e1_griego's Avatar
Drives: Many
Perrin CBE is a 2.5" flat flange, not the stock style donut.
I just did this with nameless fp/op which has a provision for the stock donut gasket, as well. Didn't use the donuts, just used the flat gasket and the protrusion from the fp/op fits inside the Perrin no problem and seals fine.
The Following User Says Thank You to e1_griego For This Useful Post:
mike7792 (02-23-2016)
Old 02-23-2016, 07:50 PM   #8
mike7792
mike7792's Avatar
Thanks for the info !
Gonna try and get it installed tomorrow at the muffler shop
WTB: Perrin Overpipe, Perrin Frontpipe SPCorBUST Want-To-Buy Requests 0 06-24-2015 06:09 AM
Brand New unused Berk Frontpipe 250$ azynneo Engine, Exhaust, Bolt-Ons 2 06-13-2015 03:52 AM
WTB Perrin 2.5 frontpipe veck Want-To-Buy Requests 2 10-07-2014 04:34 AM
Berk Dual Muffler Delete Install Question davidchoi Engine, Exhaust, Transmission 17 07-18-2013 01:07 PM
