Old 07-11-2013, 12:13 AM   #1
davidchoi
davidchoi's Avatar
Drives: BRZ - White Satin
Berk Dual Muffler Delete Install Question
So I just received it in the mail today and my buddy and I were going to put it on a ramp and install it. But his garage was robbed the day before I got it in the mail. I don't want to buy the tools to do it and use my jack.
How much do you think it's going to cost me to get it done at a shop?
Any socal shops near burbank/glendale/pasadena that won't rip me off?
Thanks guys.
davidchoi is offline   Reply With Quote
Old 07-11-2013, 12:24 AM   #2
gotchobo
Drives: Firestorm FR-S
You don't need ramps/jack to install. All you need is two wrenches to unbolt the stock axelback and some pliers to push the hangers out of the bushings.
gotchobo is offline   Reply With Quote
Old 07-11-2013, 12:26 AM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
installing this only takes me 15-20 minutes every time i do an install.
shops would definitely charge you an hour of work.
i suggest DIY. you dont need a jack.
i can install these mufflers with only hand tools.
86_ZN6 is offline   Reply With Quote
Old 07-11-2013, 12:37 AM   #4
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
wrench your own ride!
chulooz is offline   Reply With Quote
Old 07-11-2013, 01:34 AM   #5
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
The worst part is wiggling the stock muffler off the rubber hangers - that part takes about 10 minutes on the ground without ramps using a basic ratchet set.
supramkivtt2jz is offline   Reply With Quote
Old 07-11-2013, 08:27 AM   #6
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Spray the rubber hangers with a silicone type lubricant and they will slide right off.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 07-11-2013, 08:40 AM   #7
sklimo
Get dirty!!! Easy install
Old 07-11-2013, 12:14 PM   #8
bcmakesiteasy
Drives: 2013 FRS Ultramarine
I know absolutely nothing about cars and I did this myself in less than 30 mins. Just have a wrench handy. I didnt use a jack, i just laid completely flat on my back under the car and unbolted the bolts using the wrench from the stock exhaust. The only tricky part is pulling off the stock exhaust off the hangers which can be a pain in the ass. Then just bolt on the berk piece, hook it to the hangers and you're done.
FR-S Ultramarine: Berk Technology Dual Exit Muffler delete, all around tint, plasti dipped emblems/rims, ddm tuning HID 6000k kit
bcmakesiteasy is offline   Reply With Quote
Old 07-11-2013, 05:00 PM   #9
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
dish soap also works very very well and is usually readily available
Old 07-12-2013, 09:51 AM   #10
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Does this exhaust piece make the engine note unbearably loud? Are there any dyno gains to be had from this modification?
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 07-12-2013, 10:00 AM   #11
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
as others said, only basic hand tool will work. use prybary with socket to have leverage if you can't unbolt. hangers will be hardest part on this.
Old 07-18-2013, 02:53 AM   #12
ultra_frs
Drives: 2013 Scion FR-S manual ultramarine
I just finished installing mine. What exactly are these for? Nobody mentions them. Are they supposed to go on the hanger somewhere?
Sorry if this is an incredibly stupid question, but I don't want this new exhaust falling off on the highway.
My install started with unbolting the 2 bolts on the flange. Then I pulled the muffler off of the 4 hangers. 2 of the rubber things are still on the stock muffler, since the delete pipe only has 2 hangers vs 4. I bolted the delete pipe to the flange, and hooked the 2 hangers onto the rubber pieces. That's basically it.
ultra_frs is offline   Reply With Quote
Old 07-18-2013, 03:37 AM   #13
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Those look like they should go on the hangers on the muffler delete, after it is installed, to keep the rubber exhaust hangers from sliding off of the metal rod hangers on the Berk piece.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 07-18-2013, 07:39 AM   #14
CaptainSlow
CaptainSlow's Avatar
There is quite a lot of drone inside the car with this piece. It was a bit too loud for me, so I had a resonator welded in the pipe between the two tips. Definitely cut down on the drone, especially in the city driving rev range (around 1,000 to 3000 rpm). Without the resonator, a lot of the drone is in that range...with the resonator it quiets it down overall and moves up a bit in the rev range.
Not sure how to explain that better, but basically without the resonator it would drone heavily during acceleration, deceleration, and in the rev range where you are normally driving at city speeds (35-45mph). With the resonator, the acceleration and deceleration drone have quieted down a bit, there is virtually no drone at city speeds, but now there is drone at freeway speed (80mph). Since I do most of my driving around the city, I feel like this is a great trade-off.
Here is a video I made right after I installed it (rest of the exhaust is 100% stock):
[ame="http://www.youtube.com/watch?v=NVcRM-w0h4c"]Berk Dual-Tip Muffler Delete (2013 FR-S) Before and After - YouTube[/ame]
Note: The video was taken with the car in the garage, so there is a little reverb in the sound. It gives a good comparison, though.
Picture of the resonator welded in place:
To answer your final question, I don't believe there are any performance gains as far as power...there is a bit of weight savings, though. The Berk piece is much lighter than the stock muffler piece
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Berk Technology Dual Muffler Delete Group Buy!!! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 93 12-16-2013 09:54 AM
WTB: Berk Dual-Exit Rear Muffler Delete sittinSideways Engine, Exhaust, Bolt-Ons 6 06-14-2013 01:54 PM
mods to compliment the berk dual muffler delete bcmakesiteasy Engine, Exhaust, Transmission 5 01-15-2013 04:19 PM
FS: BERK Muffler Delete Dual Tip stanm Engine, Exhaust, Bolt-Ons 17 12-03-2012 10:13 PM
Berk Technology Dual Exit Muffler Delete jeebus Engine, Exhaust, Transmission 7 10-16-2012 09:38 PM
