Northwest AK, ID, OR, WA
Old 02-21-2016, 02:54 PM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Secondary o2 sensor needed in Portland ASAP!
Anyone have a secondary o2 sensor sitting around? We've got Carly's car here with a factory-seized sensor in the OEM header as we are trying to install her aftermarket header. If we can locate another o2 sensor as a "just in case" then we can proceed with removing the seized one from the OEM header. Otherwise we have to reinstall the stock header.
Reply here or text Darren, Richard or Carly if you have one. Thanks!
Old 02-21-2016, 07:38 PM   #2
Zaneman
Drives: 2013 BRZ limited
It won't come out. I put so much time into trying to get the stock one out and just ruined it instead. What I would suggest is getting a bolt the same size as the 02 sensor from Ace hardware and plugging the rear hole. I drove around like this for about a week until I got the new sensor which can be installed without removing the header and just required taking off the underplate. I got a bosch 02 sensor from autozone for around $80 last year.
Zaneman is offline   Reply With Quote
The Following User Says Thank You to Zaneman For This Useful Post:
Spechtre (02-21-2016)
Old 02-21-2016, 08:04 PM   #3
DarrenDriven
NW Region Moderator
Thanks, man. Richard and Carly finally gave up on it when the o2 sensor rounded off. A new o2 sensor should be here Monday or Tuesday and they'll finish it up.
needed asap stock catback Hyper4mance2k DIY (Do-It-Yourself) Guides 3 04-17-2015 09:47 PM
Secondary O2 sensor needed for Cruise control? DJCarbine Engine, Exhaust, Transmission 31 04-10-2015 08:49 PM
Help needed ASAP red1993sol Issues | Warranty | Recalls / TSB 6 10-13-2014 12:19 AM
Need downstream O2 sensor ASAP! mtimney Engine, Exhaust, Transmission 8 11-06-2013 12:12 PM
Help NEEDED ASAP, Thanks in advance! FR_Soldier_77 Other Vehicles & General Automotive Discussions 9 03-20-2013 10:10 AM
