Old 10-12-2014, 03:27 PM   #1
red1993sol
Drives: 2013 white BRZ
Help needed ASAP
Performed a basic oil change and looked at the air filter left it sit over night. I went to drive it today went 100 yards noticed it sputtering pulled over and it died. Tried re starting and it starts and dies as soon as it starts . Cars all stock with 12k. Any advice where to look not real happy with it right now. Thanks for any help in advance!
red1993sol is offline   Reply With Quote
Old 10-12-2014, 03:57 PM   #2
kodyo
Drives: Scion FR-S
Check oil level to make sure it's correct. My oil change was 5 quarts to fall between min/max mark. Check that the wires for the MAF sensor are ok?
kodyo is offline   Reply With Quote
Old 10-12-2014, 04:09 PM   #3
red1993sol
Checked all of that . Everything checked to be fine.. And of course it's sunday so no shops are open..
Old 10-12-2014, 04:18 PM   #4
Ozzman
Drives: old
Make sure the airbox is installed properly, if the intake tube is not attached to the airbox correctly it will cause that problem.
Ozzman is offline   Reply With Quote
Old 10-12-2014, 08:40 PM   #5
steve99
Oiled or dry air filter.
Pull out maf sensor and check its clean, last bloke that had similar issue mouse chewed his air filter (he left it overnight and filter had grass seeds in it which mouse took a liking too, no joke) and bits of air filter collected on maf sensor.
check the sound tube and crankcase breather pipes connected to inlet hose.
Old 10-12-2014, 10:21 PM   #6
red1993sol
Stock dry filter but it's all good now went back an hours later started it and had to lightly rev it for a second then everything smoothed out right away and has been fine since really weird though, wondering if something wasn't stuck on the maf for a short time .. Thanks for the help though!
Old 10-13-2014, 12:19 AM   #7
Might want to check and see if it was. If it did it once it could again and of course it won't happen at the best time.
WTB - FRS/BRZ TPMS ASAP set drftxx Want-To-Buy Requests 1 03-19-2014 12:18 AM
Need help for class, ASAP! husker741 Off-Topic Lounge [WARNING: NO POLITICS] 1 11-20-2013 08:51 PM
Help NEEDED ASAP, Thanks in advance! FR_Soldier_77 Other Vehicles & General Automotive Discussions 9 03-20-2013 10:10 AM
E34 M5 gotta go ASAP DanoFA20 Cars for Sale/Trade 12 02-10-2013 09:12 PM
NEED HELP ASAP!!!!!!!!!!!!!!! ArKiTeCkT Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 35 08-27-2012 10:24 PM
