Old 02-15-2016, 01:10 AM   #1
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
CEL P2109 P2119
I was trying to start my car and I realized that I had two CEL codes. Used an OBDII and found out I had these two codes. P2109 - Throttle/Pedal Position Sensor A Minimum Stop Performance and P2119 - Throttle Actuator Control Throttle Body Range/Performance. Anybody have any idea whats wrong and how I can go about fixing it? Thanks in advance.
EDIT: this issue that I am specifically facing may be related to a crash.
Other thread link: http://www.ft86club.com/forums/showthread.php?t=101580
driftking96 is offline   Reply With Quote
Old 02-15-2016, 02:14 AM   #2
humfrz
You might try taking off the negative battery terminal for a minute ... then re-clamp it.
That will reset the ECU and maybe the codes won't come back.
Maybe it tossed the codes because of the cold ...... it just sneezed.
OR ....... maybe:
http://www.autocodes.com/p2119.html
humfrz
Old 02-15-2016, 07:24 PM   #3
driftking96
OR ....... maybe:
humfrz
It may be possible that I got those codes due to having a piece of plastic lodged in the throttle body. I linked the other thread in the edit just in case any one else (including you) may/would like to reference themselves or learn more there. Thanks humfrz
Sent from my ONE A2005 using Tapatalk
The Following User Says Thank You to driftking96 For This Useful Post:
humfrz (02-15-2016)
