Old 02-13-2016, 08:29 PM   #1
Kendallkab
Drives: Black MT LMT BRZ
18" wheels with car lowered
If anyone has one of our 86's with 18" wheels and the car lowered can you please provide pics and put how much its lowered. I want to know if it would be possible to lower this car 1 or 1.5" on 18s and if so what it would look like. Thanks in advance.
Kendallkab is offline   Reply With Quote
Old 02-13-2016, 09:38 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Tire size (diameter) has no bearing on how far you can lower the car. The overall diameter of the wheel/tire combination still remains the same because you put lower profile (thinner) tires on a larger rim.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Kendallkab (02-14-2016)
Old 02-13-2016, 09:57 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
look in the wheel directory. Tons of good info. I've read through most of it.
Old 02-14-2016, 03:29 AM   #4
Irace86
Drives: BRZ + Ducati M796
It usually is close, but often isn't exactly the same. I'll be a few percentage larger when I get my setup, but you are right, it isn't because of the rims are 18's; it is because I am choosing a tire that has a slightly larger diameter than the stocks.
To the OP: What Leonardo said... lots of pics in the directory.
Irace86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Irace86 For This Useful Post:
Kendallkab (02-14-2016), Leonardo (02-14-2016)
Old 03-26-2016, 09:13 PM   #5
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Look in my garage. 18's and lowered .8.
vintagemxer is offline   Reply With Quote
Old 03-26-2016, 11:03 PM   #6
mpross
mpross's Avatar
Drives: 2015 Scion FRS
18x8.5 front and 18x9.5 rear with about a 1.75-2 inch drop from buddy club racing spec coilovers. First two pics were closer to 1.5 inch though.
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Has anyone lowered just the rear wheels? buckseventysix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-24-2015 01:53 AM
lowered my car 1 1/2" but want to add spacres JMARTINEZ2421 Southern California 10 06-20-2014 07:44 PM
Lowered on stock wheels and tires 11RApearl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-30-2014 01:34 PM
Has anyone done 17X8 +30 on stock suspension or 1" lowered? BRZZZZZZZZZZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 12-31-2013 11:37 PM
Lowered car about 1.25" Adjustable Endlinks needed? Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-21-2013 09:40 PM
